I'm at 320K miles on my 1995 6.5L now. She is showing no signs of slowing down or wearing out either.
Forgot to mention my truck is a 04 with the LLY. All stock.
Thanks for the advice More Power.
I know it's a late entry, but I'm attempting to post a pic of my Odo from my (former) 2001 2500HD. 436,767. Recently sold....
(somone let me know if it doesn't appear anywhere...)
"Chessy56"
So. Milwaukee, WI
'01 2500HD, LB7, ~440K miles
Winston Churchill
414,000
Hummer wheels :^)
dual lift pump
Banks air intake
427,300 miles and counting..
05 gmc 3500 497,ooo kms and still good
2005 gmc 3500 c/c 4x4 dually 2015 Sierra 377FLIK 14,000lbs
Rebuilt Allison w/ billet torque converter and upgraded clutches
lly Duramax
edge juice w/attitude
Kennedy boost stick
banks air box
MBRP 4" SS
egr blocker plate and finger stick
head studs
Wow that’s cool maverick_935..
Hummer wheels :^)
dual lift pump
Banks air intake
The ol' Tahoe made it to 375K miles before popping a head gasket in July of 2021 - she showed no symptoms of any issues at all, but suddenly popped without warning, causing the rear two cylinders to fill with coolant when sitting for more than a few moments. I could have slapped some gaskets back on and called it good, but ended up rebuilding a low-mileage 506 block to drop in, and I've currently got around 390K on the clock and about 15K on the new engine.
Don't know what happened to my post, but mine is a 2004 GMC 2500 with 252116 miles. No real problems but glow plugs, vacuum pump and batteries. Sorry previous post I was guessing milage, this is the actual as of right now.
