All of the sudden my o/drive and tow haul indicators do not light up on the instrument panel
is there a fuse or what else do i look for. 2003 dura max.
ORDERED 1-15-03 ARRIVED 2-10-03= 03/2500HD/D/A/EXT.CAB LT/ LONG BOX/4X4/CARBON METALLIC/ONSTAR/ TTT CAMPER MIRRORS/WESTIN BOARDS WITH LITES/HUSKY FLOOR LINERS/PRO FIT FLAPS/ACCESS TONNO/LINEX BED RAILS/ FUMOTO OIL DRAIN VALVE,
BEDRUG/BILSTEIN SHOCKS/ ISSPRO EGT GAUGE/RED LINE LUBE, BANKS EXHAUST BRAKE. GALAXY 929 CB/ WILSON 1000.KENNEDY LIFT PUMP.
If the T/H and/or others lamps don't light up, but they function, it's probably the IPC (Instrument Panel Cluster). Not an uncommon failure. If it bothers you, send it in to get repaired (and upgraded, if you like). Or, just wait until other parts of it fail, like gages.
On second thought, try a computer reset. Disconnect BOTH batt+ terminals at the batteries, ground one to chassis for 30 minutes, then reconnect. Free to try.
It's only the t/h and over drive lockout that don't light and the t/h and over drive do not funtion.
It's the momentary switch in the shift lever, or a harness wire has parted. I think, for the 2003, you have to replace the entire lever. You can try to "exercise" the switch (peck it quickly for several minutes), but it's usually only temporary, if it works (supposedly "cleans" the contacts). If you replace the lever, have a new lever boot handy. If original or old, it will likely disintegrate when you mess with it.
Thank you. Will try that.
That's great! Sometimes, you win.
