TheDieselPage.com Forums
2018 - TDP's 22nd Anniversary
Go Back   TheDieselPage.com Forums > Chevrolet & GMC 2500HD/3500 Light Trucks > Duramax 6600
Duramax 6600 Discussion Forum for the Duramax 6600 Diesel Engine, including the LB7, LLY, LBZ, LMM & LML engine specific topics.
Closed Thread
Thread Tools Display Modes
  #1
Old 04-22-2003, 11:08 PM
FRMLPLR's Avatar
FRMLPLR FRMLPLR is offline
Enthusiast
Question
Have been raw fuel smell in cab last couple of days. Tonight park truck, come out later in evening 12" diameter puddle under right side of truck. It appears to be coming off the right side of the bell housing. Can see anything above this that it is dripping from.
Any thoughts?
  #2
Old 04-23-2003, 05:04 AM
dmaxalliTech dmaxalliTech is offline
Enthusiast
possibly the fuel filter, as it mounts on pass side, but its forward of the bell housing, extreme cause could be leaking injector pump, filling valley of engine. When you take off, it could slosh back there. I would check the fuel filter first. The injector return line comes from the front of the head on pass side so thats probably not it. Do you have hard start or other symptoms????
__________________
2003 GMC Sierra 2500 HD CC Shorty
Dyno Proven - 800 rwhp on fuel only.
Trans to hold it and a big ol S400 turbo feeding it.
  #3
Old 04-23-2003, 07:24 AM
FRMLPLR's Avatar
Enthusiast
Thumbs down
Fuel filter is dry, but will climb up and check the valley. We are off to the dealer this morning.
Thanks!
  #4
Old 04-23-2003, 10:24 AM
3-Fan 3-Fan is offline
Enthusiast
I had a fuel leak a while ago. I had a fuel line that was loose at the injector. Dealer replaced the fuel line and have had no problems since. Mine was on the drivers side. The fuel would leak down the block and drip out and run down the frame, tranny and it seamed about everywhere. Quite a mess. The whole underside was coated in fuel along with the sheet metal inside and out from the front wheels back. I could not see the leak from above, but could see it dripping form below.
Might have the dealer check that out.
Good luck.
__________________
2002 2500HD DA LS ExC LB 2WD, HOT Juice, Predator 1.04, BANKS Monster Exhaust, Deep Pan Alli, JK HB Kit, TTT Mirror, XM Sony PnP, High Idle w/ PTO Switch, Armacoat Liner, Black like the #3!<a href=\"http://community.webshots.com/user/3and77\" target=\"_blank\">PICS</a>
  #5
Old 04-23-2003, 02:04 PM
Enthusiast
3-fan, I cant believe you didnt have a drivabilit issue. One more note, I have seen the FRPR leak also, its right behind the injection pump
__________________
  #6
Old 04-23-2003, 02:30 PM
Enthusiast
Didn;t have reduced power or anything. Of course I was running HOT juice for the 1st time too, so maybe that compensated a little. I did have an extremely large cloud of evaporating fuel from the truck on the drive home. I bet you the people behind me got a good coating of diesel fuel too!!! Noticed it about 5 miles from home so I didn't drive it far that way. Had AAA coem take me to the dealer.
__________________
  #7
Old 04-23-2003, 03:30 PM
Kennedy
Guest
Posts: n/a
The most common leak that I have seen has been the rail psi sensor located on the function block.
  #8
Old 04-23-2003, 06:10 PM
FRMLPLR's Avatar
Enthusiast
This is why I like this site so much!!! i Appreciate all the thoughts. Tech thinks it is at the function block. Will bring back tomorrow for them to tear into!
__________________
'02 GMC,Duramax/Allison "FRMLPLR"(FarmallPuller) WORK
'06 VW Jetta TDI ECONOMY
'06 C6 Z-51 Convertible FUN
Closed Thread
Thread Tools
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
