I saw a previous post that said stay away from the plastic body filters . what is the problem with these ? I just put one on from Napa .
Brian Dupont
2002 Chevrolet 2500 ext Short Box Duramax
429000 miles and counting all stock accept for airbox mods
2015 2500 Silverado Duramax LTZ Z71 Crew cab Standard box
The problem (seldom seen) is a leak between the filter face and the filter mount face. The O-ring on the filter can't get a great seal between the housing and the sometimes warped piece of plastic that is the filter itself.
Uncommon problem with a plastic NAPA filter. Practically unheard of problem with a steel case filter.
I prefer the OEM filter. It's steel case, it works well, and the filter threads onto the housing easily. Some aftermarket filters have the threads cut into the filter case starting a bit too deeply and can be a genuine PITA to install in my experience (Baldwin comes to mind).
I have been using Baldwin filters since my truck was new and I have never had a problem installing one. I guess I'm just lucky, or after changing the filter 16 times maybe I have just gotten good at it.
Ed
KM4STL
All other filters are multi layer. The Wix/Napa/Car Quest units are single layer. They are also prone to leaking air in. I've seen a good many cases where the filter was installed and immediate issues only to be cured with changing back to a higher quality unit.
Our Baldwin unit prices lower than Napa in most cases.
