TheDieselPage.com Forums
2018 - TDP's 22nd Anniversary
Go Back   TheDieselPage.com Forums > Chevrolet & GMC 2500HD/3500 Light Trucks > 2500HD/3500 HD Trucks & Drivetrain
2500HD/3500 HD Trucks & Drivetrain Discussion Forum for the 2001 & newer 2500HD/3500 Trucks, Transmissions & Drivetrain
Reply
Thread Tools Display Modes
  #11
Old 04-07-2018, 06:47 AM
DmaxMaverick's Avatar
Administrator
It doesn't have to get too expensive. You will however, need to get your hands on a capable scanner (or pay a shop or dealer) to actually see what's (not) going on during a start attempt. While cranking to start, several things have to happen (assuming the engine is otherwise healthy and able to provide correct timing and compression). Primarily, the high pressure fuel system must meet minimum pressure, and the injector driver must command injector events.
Something as simple as a HP regulator or purge valve failure (for a variety of reasons) will prevent sufficient pressure to initialize an injector event. This can be easily seen with many/most scanners, including the simple, inexpensive "phone app" adapters. Connecting a scanner can also indicate the function of the computers. Missing values that should be present may indicate harness damage or failed computer modules. I'd start with checking the harness connections at the PCM and TCM, which are the easiest to access, and follow the harnesses checking for damage. A simple rodent intrusion could cause everything you've seen, which should be evident by their habits (nesting) and damage they do. I live in the sticks, and have visited this issue on several vehicles over the years, including a 2000 Impala that burned itself to the ground in my driveway, likely caused by rodent damage.
__________________
  #12
Old 04-07-2018, 08:54 AM
Yukon6.2 Yukon6.2 is offline
Enthusiast
Seeing you have the block heater found...
Try plugging it in for a couple of hours and then try starting it.
Are you getting any smoke from the exhaust when you try to start it?
__________________
  #13
Old 04-07-2018, 08:57 AM
Cold water Cold water is offline
Enthusiast
O.K., will look at those options. Just sent a text to my neighbor who is a 25 year Nissan mechanic whom has a real scanner.
Just a thought. I converted my headlights to HID back in November. In February I had a 1900 mile trip in one week. On the way home I hit the high beams and my programmer reset itself (powered off then back on). Could this have been a warning?
I live in the sticks also. Thank God I have yet to have one burn to the ground.
__________________
2003 Ext. Cab Long Bed
Banks Cold Air
Banks Exhaust
Early Edge w/Attitude
  #14
Old 04-07-2018, 09:56 AM
Administrator
This ain't your grandpa's GM Diesel. The GP's (and intake heater) are used to satisfy the EPA and smooth a start when it's really cold (well below freezing). The engine will start with the GP's disabled down to any reasonable cold start. Rough starts don't show up until around 10F and below, and even then, it will start without much hesitation (it takes a few seconds to smooth out, though). The high pressure fuel injection (north of 4K PSI during a cold start) eliminates the requirement for functional use of the GP's. I haven't used the GP's for cold starts in over 10 years.
If it isn't starting, or trying to start, it isn't getting fuel.
If it's getting fuel and not firing, it WILL smoke, just like grandad's old oil burner.
__________________
  #15
Old 04-07-2018, 09:59 AM
Administrator
That could certainly have some contribution to a problem. Still, a scanner will help get you looking in the right direction. If the Edge module reset, there's something amiss with the electrical system, or the PCM or its harness. Could be a lost ground, somewhere.
__________________
  #16
Old 04-07-2018, 10:15 AM
Enthusiast
Roger that! Neighbor is working today and said he could come by in the morning.
__________________
Banks Cold Air
Banks Exhaust
  #17
Old 04-08-2018, 12:42 PM
Enthusiast
O.K., so the neighbor came by with the scanner he uses at his house not the one he uses at work. Bigger and nicer looking than the one I have, but almost as useless.
He said I should open up the fuse panel under the hood on the drivers side and check for corrosion since the local free loading mice decided to use it as a restroom and dining hall. I pulled every fuse and checked them. I then pulled it apart from the underside looking for corrosion. Some of those connector were a bugger getting undone. The underside looked almost as good as the day it was installed. I also checked the wiring harness' for any wear. None was found.
Before he came over I pulled the HID headlights out and disconnected them, no change. I also pulled the fuse for the auxiliary LED back lights I installed back in November and still no change.
I replaced the ignition switch about a month ago for the "Range Shift Inhibited" message. Is it possible that I did not do this correctly or that it went bad already?
__________________
Banks Cold Air
Banks Exhaust
  #18
Old 04-08-2018, 01:52 PM
Administrator
Once you have rodent evidence, all bets are off. They go where you won't/can't see. The only option is to keep looking. Good luck with that!
"Shift Range Inhibited" is almost always the NSBU switch (located on the tranny where the shift cable connects), or the connector. If your new ign. switch fixed that, it would be in the more rare category (not that ign. switches don't fail on occasion). Even if that were in play, right now, it won't cause the problem you having, right now.
If damage was done by a modified electrical system (if that happened), disconnecting them won't likely "fix" anything. Damage done is damage done, and won't change unless and until repaired. Stray voltage and errant grounds have caused more headaches than just about anything, especially with these late model mobile super computers.
Were you able to identify any DTC's (Diagnostic Trouble Codes, or 'codes', for short)? It's an essential piece of your puzzle, at this point. Still, you really need a capable scanner to know what's going on that you can't see. At the very least, set yourself up with an ELM327 adapter (cheap) and pair it with a smart phone or tablet (download the Torque Pro app, also cheap). It will allow you to see the most essential codes and values you need right now. Also, if you have a friend with a Predator programmer (2003+), it will show you much the same (it doesn't have to be married to a vehicle to see passive values, only for uploading tunes).
__________________
  #19
Old 04-15-2018, 01:37 PM
Enthusiast
UPDATE!!!
My apologies for not getting back sooner. Life, work, etc., etc.
O.K., So I scheduled an appointment with the local Chevy dealer on recommendations for a couple of shops in the area. Apparently we do not have a "true diesel" shop in the area anymore. The truck was picked up via flatbed on Thursday night and taken to the dealership. I called them Friday morning to let them know everything I had already done. That evening I received a call from the service writer telling me that all of the electronics are in good working order and my problem seems to be the fuel pressure regulator. It is either bad or clogged. They are not 100% sure if this in the only problem since they have yet to get the truck to fire up. They do know that the fuel is getting to the engine but then it returns to the tank. I will know more on Tuesday when they get the part in. I am hoping that is the problem since the estimate is just under $1100.00.
I truly have enjoyed this truck since buying it in Oct. of '09. Using it for everything from hauling a 1995 Weekender by Skyline (really large truck camper), firewood, towing a couple of vehicles and the occasional dump trailer (neighbor used to have one) to get mulch for the wife and neighbor. But, this past year has been expensive. Brake hard lines (THANK YOU GM you almost killed me and possibly someone else) fuel lines, radiator and upper and lower hoses. Let us not forget about the injectors five years ago. Yes, I know the truck is 15 years old.
Anyway, sorry for the mini rant. I will keep you up to speed as soon as I can.
__________________
Banks Cold Air
Banks Exhaust
  #20
Old 04-19-2018, 10:29 AM
Enthusiast
Hey everyone,
Well my day just got dumped on. On Friday they told me that they thought it was the fuel regulator($1100.00). So they replaced that today(it had to be ordered). Today they are telling me that the fuel injector pump(CP3) has something wrong with it. The truck will idle but as soon as you put a load on it it dies. So now we are at an additional $3000.00. Since this is not in my budget I told them to push the truck outside and I will have it towed off of their lot.
NOT what I needed to hear!!!
__________________
Banks Cold Air
Banks Exhaust
Reply
Thread Tools
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
