Old 11-17-2017, 05:52 AM
gsimpson gsimpson is offline
Default Rocker arm retainer buttons
OK so, I was on here reading about rebuilding my heads and someone suggested that I replace these plastic rocker arm retainers ( thinking it was Robyn). Now who sells these as I am having a hard time finding them and was told they were cheap? I have only found them on EBay at 7.45 EACH. Which to me is high priced for plastic.
Anyone know of a good place to purchase these?
Again thank you all for the advice and help.
Gary
1995 Chevy 2500, 6.5L Diesel mostly stock 234,000 miles. Changed the water pump to HO WP, deleted the vacuum pump and added a mechanical wastegate controller made by me with info from others on the forum.
Old 11-17-2017, 06:29 AM
Robyn's Avatar
Robyn Robyn is online now
Missy Good Wench ( Moderator)
Check this out
https://www.google.com/url?sa=t&rct=...q5w0uz8M6fbe33
$1.77 each
(1) 95 Suburban 2500 4x4
(1) 2017 Mercedes C class
Old 11-17-2017, 06:56 AM
trbankii's Avatar
trbankii trbankii is online now
RockAuto.com
50₵ each.
94 GMC 6.5TD K1500 4L80E 2-Door Yukon SLE 216K
93 Chevrolet 6.5TD K2500HD NV4500 Std. Cab Longbed 184K
85 Toyota 22R RN60 4x4 Std. Cab Shortbed 178K (Currently retired for rebuild)
Old 11-17-2017, 06:59 AM
Default Thank you
Very much Missy!
  #5
Old 11-17-2017, 07:13 AM
Robyn's Avatar
I listed the part # in the 6.2/6.5 tech forum under useful part numbers
You are welcome
  #6
Old 11-17-2017, 07:24 AM
Robyn's Avatar
AS mentioned Rock auto is cheaper MR1948 part number.
When you install these use a round shaft of similar size that covers the button and tap into shaft carefully.
Set the shaft in the cradles in the head and secure with the end bolts and then install buttons.
Keeps things secured and easy to manage.
  #7
Old 11-17-2017, 10:19 AM
JeepSJ JeepSJ is offline
Jeep Freak
Wasn't someone making a steel replacement at one point?
