Results 1 to 17 of 17
Thread: Fuel Tank Sock Part Number
    May 2004
    Salem, Oregon
    Default Fuel Tank Sock Part Number
    Going to drop my tank this weekend and give it a thorough cleaning. Had a batch of bad fuel...gunked up a couple of filters, so my sock is likely in as bad of shape.
    Does anyone have a part number and source for an aftermarket fuel tank Sock? Called GM and they dont carry (or so they claim), but were happy to sell me a $400 sending unit with it included. Napa didnt either.
    Thanks in advance.
    BrentN
    1999 Suburban 2500 4x4
    176,500 miles,4.10,K & N Air Filter
    Kennedy 3.5" Exhaust, Remote Mounted FSD Cooler
    Kennedy Boost Fooler, Homemade Intercooler (Dieselpage Model)
    Derale Fan Cooled Tranny Cooler (under body mount)
    A Pillar Pod (Isspro Boost, Pyro & Trans Temp)
    2014 Cruze 2.0 Diesel- Tuned and loving it.
    Kerma TDI Tune (+35hp/75lb-ft).
    55.7 MPG best average thus far
    2008 Grand Cherokee, 3.0L Mercedes Diesel
    Tuned- 240hp/440lbs - Amazing out of a 3.0L
    1998 Dutch Star 38' Diesel Pusher, 8.3 Cummins, Allison 6 spd, 9.9-10 mpg
    Stock 300 hp/850 ft-lbs
    Feb 2012
    Pauline, SC
    You would maybe be better off to remove the sock and add a pre LP filter, they can be found cheap at NAPA and are easy to install, no more clogged socks... while you have the tank down you might want to install the new style P/U & sending unit, no more gauge bounce and much more accurate tank readings.... I don't know if I am allowed to post a link to the part here, I don't think any of the vendors here sell it, PM me if you want the link..
    You can clean the sock very easy, if it's not coming apart..
    1993 Chevy K3500
    like us on Facebook
    Default Don't do it!
    Recurring theme as of late. Aftermarket sender (with sock) and hair pulling headaches ensue.
    Aftermarket parts are often good, but more often inferior as has been the case here. Ask Casey (Arveetek) and I think there was one other that followed shortly after.
    Just took a call yesterday from a guy with a 93 and new aftermarket sender. Truck went like 200 miles then shut off with filter full of air.
    Feb 2012
    Pauline, SC
    John, do you know what brand it was, I have had very good results with the one I installed, hope it doesn't croke on me now....
    1993 Chevy K3500
    like us on Facebook
    May 2004
    Salem, Oregon
    Thanks all. I will pull it down and give it a good soaking and a wash as well as the tank and put it back together. If it is trashed I will order a new sending unit.
    BrentN
    Yeah, it took me several months to figure out that it was the aftermarket "sock" that was squeezing down and shutting off fuel flow. I reinstalled the OEM "sock" and all has been good since.
    I don't know if you can even find an OEM "sock" by itself. Like the original poster, the only option I found was a GM sending unit assembly with an insane price tag.
    If you really do have a clogged OEM "sock", you should be able to take it off and clean it well with brake cleaner or some other solvent, and be back in good shape.
    May 2004
    Salem, Oregon
    Thanks Casey. Didnt get to the cleaning this weekend. Maybe this week. Always something coming up.
    BrentN
    Feb 2012
    Pauline, SC
    I found this....
    Part: Fuel Tank Sock
    Part Number: 25055272
    Manufacturer: ACDELCO
    1993 Chevy K3500
    like us on Facebook
    May 2004
    Salem, Oregon
    Thanks for the part number
    BrentN
    Jul 2003
    Allentown, PA
    Brent, if you have time, could you post as to "how" you went about dropping the tank and how it went for you? It doesn't look to be all that hard, but I sure wouldn't mind reading about your experience.
    Apr 2010
    Quote Originally Posted by DennisG01 View Post
    This isn't meant to sound cocky but:
    Drain or run tank to near empty, support tank (across broad surface like a slab of plywood and a floor jack), disconnect filler tube, disconnect feed/return lines, remove straps, lower tank.
    Remove tank sender/pickup unit by removing locking ring and lift out of tank.
    Install in reverse order.
    The rest is just spinning wrenches.
    Of course, you could just remove the bed if you find that an easier route.
    Like 6 bolts, the filler tube and some electrical connectors and it will lift free.
    Well, it will with a lift or 4 strong friends....
    1998 k2500
    Jul 2003
    Allentown, PA
    Quote Originally Posted by greatwhite View Post
    Thanks. I don't need to do it right now, but I've been under there for other things and looked at it in regards to "what if". I thought it was pretty straight forward - but was mainly curious if I was over looking anything. From what you wrote, it appears it's as straight forward as I was thinking.
    I've got a Burb... it might take more than 4 friends to lift the "bed"!
    The Burb should be even easier. Roll back carpet and insulation above the tank. If there isn't an access hatch above the tank, make one. Some model years had one, some didn't. I've never nailed down the years/models that originally had one. If it were me, I'd also install a low-point drain while messing with it.
    Jul 2003
    Allentown, PA
    Do you mean an access hatch big enough to remove the tank? Wouldn't that affect the structural integrity of the floor?
    Or, are you referring to one just big enough to get to the sending unit? I'm not sure why I didn't think of that - I'm a boater and the cockpit floors will have a "deck plate" to access the sender.
    "Low point drain"? Do you mean in the rear cargo floor?
    An access hatch for only the sender. You could make one large enough for the entire tank, I suppose. Properly done, it wouldn't compromise the structural integrity.
    A low point drain for the tank. It would make contamination clean-up a lot easier. There was a time nearly all vehicle fuel tanks had these.
    If you need a drain for the cargo area, you have bigger problems!
    Jul 2003
    Allentown, PA
    Good idea... Again!
    "drain"... Yeah, you had me scratching my head on that one!
    Jan 2009
    I found this....
    Thanks sctrailrider
    Looks like my sock is clogged and turns out the RockAuto FSU i installed 2 years ago has a gas strainer/sock and NOT a diesel sock.
    So i had to order the GM # 25055272 sock from my local dealer for $36, it will be in late tomorrow afternoon!!!!
    Can you Yahoo
    BUT, WILL it work?? meaning, will my Dorman FSU # 692097 allow me to snap off the gas sock and pop on the GM sock, man i sure hope so???
    Rock Auto FSU
    http://www.rockauto.com/catalog/moreinfo.php?pk=1027202
    RockAuto.com has the ACDelco sock # TS1012 for $20
    More Information for ACDELCO TS1012
    BUT Get this, turns out that for me locally, only 1 company carries the diesel sock
    1 AutoZone can get it $29
    2. NAPA can NOT obtain the ACDelco TS1012
    3. CarQuest can NOT obtain the ACDelco TS1012
    4. Brandywine (local 6 group private parts store) can NOT obtain the ACDelco TS1012
    5. PepBoys can NOT obtain the ACDelco TS1012
    6. Advanced Auto Parts - can NOT obtain the ACDelco TS1012
