Results 1 to 8 of 8
Thread: A/C Fan
    Jan 2010
    Default A/C Fan
    Hi,
    When I put on my air conditioner on high fan after about one minute the fan motor will shut off but all other speeds will still operate. I replaced the fan motor and still have the same problem. Any suggestions on what to look for?
    Thanks.
    Merrill
    1991 Suburban 6.2L 3/4T 4X4 Banks Sidewinder Turbo Frybridized
    Feb 2003
    Grand Rapids MN 55744
    Howdy
    A few other things to check:
    Switch issues in the dash, I cant remember how that model switches but I know in the newer trucks they ran high current through the switch and they had a tendency to burn up.
    Resistor pack for fan speed control. This is mounted in the air box and can also cause problems.
    Relay pack mounted on top of the air box
    Some trucks had a connector for the high speed circuit in the fan wire and it could overheat and become a problem as well.
    The high speed circuit is separate from the others and it sounds like yours is heat related due to the current draw.
    good luck!
    2001 Chinook RV, V10 gas
    1967 GTO, 1989 Honda Transalp
    3 kids, 1 wife, 1 dog
    Aug 2001
    San Diego, CA, USA
    Default Exact same issue
    Hi, I had the same issue and replacing the resistor pack in the airbox fixed it for me. Best of luck.
    85' Sub K-20 4x4 6.5 w/ cooling mods
    Phazer and Banks Turbo
    33" BFG's w/ Bilsteins Rebuilt 700R4 w/ all the upgrades
    Jan 2010
    Quote Originally Posted by Dvldog8793 View Post
    Howdy
    good luck!
    Thanks for your suggestions:
    It does sound like it is heat related.
    I've already replaced the resistor pack and the switch that selects the fan speeds is new. I'll try the relay pack next.
    Thanks again.
    Jan 2010
    Quote Originally Posted by Jgreemo View Post
    I've replaced that resistor pack but still have the same problem. Will try the relay pack next.
    Thanks.
    Feb 2003
    I would check for faulty connections in the wiring first.
    Most of the relays are pretty durable and fixing a connector can be free.
    Jan 2010
    Good idea!! Thanks.
    Jan 2010
    Sorry for a late reply.
    I looked the best I could for faulty wiring and found no bad connections.
    Changed the relay and all is fine now.
    Thanks for all of your suggestions.
    Regards,
    Merrill
