  #21
Old 04-02-2004, 10:13 PM
DonG DonG is offline
wxmn6,
The two sets of numbers refer to the thickness or viscosity of the oils. Very similar to motor oil like 15W-40.
The 75W-90 weight gear oil is what comes in your truck differential and is recommended most of the time.
The 75W-140 is listed in your operators manual as an alternative gear oil if your tow heavy loads in hot weather. Heavy loads would be 12,000 lbs. or above. Several people on this site feel that even when towing heavy, the 75W-90 will still be fine.
When towing 14,000 lbs. I use the 75W-140.
I hope this helps.
Don
2003 GMC 3500 SLE, D/A, EC, LB, 2WD, White/Pewter, DeeZee boards, 5th wheel
  #22
Old 04-03-2004, 06:05 AM
jbplock
Guest
Posts: n/a
Ditto's to Don post.
Also another point regarding the numbers in an oil viscosity spec…
The high number (90 in 75W-90) is measure of the oil’s viscosity when it reaches operating temperature and the low number is a measure of the oil’s cold temperature viscosity.
So, 5W-40 and 15W-40 oil have the same viscosity at operating temp but the 5W=40 will flow better when cold.
Conversely 75W-140 oil will be “thicker” when hot than 75W-90 oil but have similar cold temp performance.
[img]smile.gif[/img]
  #23
Old 04-03-2004, 09:35 AM
wxmn6 wxmn6 is offline
Thanks for excellent information. It's nice to learn about something like that.
I am just curious that if both 75w-90 and 75w-140 have same cold weather performance (which I was concerned because I live in NY where we can see sub zero temperature during the winter), then would it hurt to go with higher viscosity if you don't do alot of heavy towing? I would assume that thicker oil would give more protection? Would it (140) actually do more harm than good (than using 90), or is it just that 140 cost more than 90?
With the information given earlier, I will be going with 75w-90, but just want to learn a bit more about it.
Do the front transfer case also use 75w-90 too? If I am not mistaken, the front transfer case does not have factory sythetic, correct? If I want to go sythetic, is there something else that I need to do (other than draining) to properly clean the case so it would not get contaimated with mixed fluid? Thanks.
2002 Chevy Silverado 2500HD<br />Ext. Cab SB 4x4 LS<br />6.0L/HD Auto.
  #24
Old 04-03-2004, 09:47 AM
G. Gearloose G. Gearloose is offline
Quote:
Hmmm, you should only have one...
1996 K1500 6.5, 1984 K5 6.2 Banks both \"Stock\" (tilting hand side-side like Sammy Davis in Cannonball Run)<br /><br />Got Boost?
  #25
Old 04-03-2004, 01:49 PM
jbplock
Guest
Posts: n/a
... I live in NY where we can see sub zero temperature during the winter), then would it hurt to go with higher viscosity if you don't do alot of heavy towing? ....
Does the front transfer case also use 75w-90 too? If I am not mistaken, the front transfer case does not have factory synthetic, correct? If I want to go synthetic, is there something else that I need to do (other than draining) to properly clean the case so it would not get contaimated with mixed fluid? Thanks. [/QB]
wxmn6,
I’m not an expert on this subject but from what I’ve learned unless you are towing big loads regularly it’s best to stay with the GL-5 synthetic 75W-90. Using the heavier 75W-140 when not needed can lower your fuel efficiency.
And yes last I knew the front diff comes with 80W- 90 mineral oil but you can switch to a GL-5 synthetic 75W-90 (the 4WD transfer case uses DEXRON III). However, GM recommends you have the “white” vent cover on your front Diff for compatibility with the synthetic oil. See Feb03 GM Techlink article for more info.
It’s also not necessary to flush or clean the diffs (front or rear) when doing a routine fluid change to synthetic – the fluids are compatible. Just remove the magnetic plug, drain and refill. Also clean the plug ... the front diff plug on mine had quite a bit of “goo” on it. A small amount of metal filings is normal. (see pics)
Personally I changed both front and rear diffs to Mobil-1 75W-90 at 5kmiles. I also changed the transfer case and Allison to Mobil-1 ATF.
A search of the forum will also turn up a quite a bit of info on this subject.
Hope this helps… [img]smile.gif[/img]
  #26
Old 04-04-2004, 12:31 PM
Thumbs up
Thanks for very helpful information!
  #27
Old 09-19-2007, 10:41 PM
alaskanmax alaskanmax is offline
alaskanmax
Default G80 rear end acts like open diff???
According to some folks on the forums it is said that if you lift both rear wheels on the d-max, and rotate one wheel the g-80 limited slip will act just like an open diff and the other wheel will counter rotate. With out opening up my cover on my rear diff or getting stuck how will I know for sure what my used truck has??? I can find no stickers on dash or door areas to say it has a g-80
  #28
Old 09-20-2007, 03:37 AM
DmaxMaverick's Avatar
Administrator
Quote:
Look in the glove box. Your RPO sticker is there, and G80 will be on that list, if you have one.
If you raise both wheels and spin one slowly (tranny in P), the other wheel should turn the opposite direction. If you spin one very quickly, like a good kick, it will lock. You can also test it on a roadside shoulder, one wheel on the pavement, and the other on loose ground (less traction). You should feel it lock when you goose it and one wheel breaks traction.
  #29
Old 09-20-2007, 10:24 AM
SoTxPollock SoTxPollock is offline
ALASKAMAX, where are you located? I may have seen your truck, seems to be the truck of choice where I was last week, sure miss those 50 degree days, came back to 90 degree Texas days.
One word of caution when the locker locks, if you are on slick hard surface be prepared to back off the accelerator or you could find yourself going around in circles. On an open rear end at least one of the wheels will tend to help you keep it straight, but if both start to spin the engine torque and rear differential torque will tend to make the truck back end slide to the right. Enjoy the truck.
  #30
Old 09-28-2007, 09:36 PM
alaskanmax
I, and truck are both in Anchorage. Today, I recieved my copy of Differentials Identification, Restoration & Repair by Jim Allen and Randy Lyman. I have read most all in the past couple hours, so listen up everyone....buy a copy as this book is really good and will answer any questions on the AAM 11.5/Eaton G-80. ......Thank You to Jim and Randy
