Results 1 to 2 of 2
Thread: flickering shift indicator light
    Dec 2014
    staunton il
    Default flickering shift indicator light
    My 2002 Silverado 6.6 Duramax shift indicator light flickers no codes runs and drives fine just cant see what gear Im in.The oil change light flickers too.Does anybody have a wiring diagram for the box on the fan shroud.I think thats were my problem is.
    The "box" on the fan shroud is actually 2 "boxes". The PCM and TCM. Unless you have a real reason to suspect a problem there, such as physical damage, that's not it. Your problem is much more likely a failed IPC (instrument panel). Not too costly, and easy to R/R. About $100 to repair, if you R/R, yourself. If you replace it with another (new or used), you'll need to make a trip to the dealer for programming.
