Results 1 to 2 of 2
Thread: injector balance rate
    Nov 2011
    Walker Lake, Nevada
    Default injector balance rate
    what would be a bad number (border line) i just got a genisys evo scan tool, as soon as i learn how to use it should be able to read it. my lb7 if left ideling will start to smoke a little. i get on the road, in about a 1/2 mile it cleans up
    Mark
    02 K3500 DRW 6.6
    89 K3500 DRW 6.2 Turbo NV 4500 Conversion in progress
    88 V 30 6.2 N/A DRW TC, 65 C10 step side
    69 Stingray BB 4spd, 86 Corvette TKO 5spd ORR
    88 YJ, 77 CJ5, 77 Sanger flat bottom BBC V-drive
    41 Chev 2dr coupe BBC TH400 9" Street Rod, 97 Softail
    Quote Originally Posted by MMcGee View Post
    Simple answer.... when it sets an injector-related trouble code.
    Run some injector cleaner. I spoke with a fuel shop a while back. The owner reported that many of the injector sets he's seen that were pulled for bad balance rates or a white smoke at idle complaint were due to varnish or sticking nozzle components. Light duty use of the truck (cooler EGTs, low fuel rates, etc.) may contribute. An injector cleaner may help.
    On the other hand, if an injector imbalance is caused by worn parts, the situation won't improve despite the best elixir you pour into the tank.
