Results 1 to 12 of 12
Thread: Injector Lubrication ??
    Jun 2005
    St. Augustine, FL
    Default Injector Lubrication ??
    Automatic transmission fluid or 2 cycle oil ??
    2005 Chevy 2500HD, CC, SB, 4X4, Duramax, ARE Topper, 60 gallon RDS toolbox/tank combo, Kennedy Headlight Booster, Isspro pyrometer and boost gauges, EGR Blocker, PCV Kit, Bilsteins, 265 Michelin MS-2, TTS Exhaust, pulling 35' Jayco travel trailer.
    GM says no additional lubricant is necessary, but......
    One is designed to resist burning. The other is designed to burn cleanly. 2 cycle oil, without a doubt. Also, make sure to use TWC3 oil. It's for water/liquid cooled engines and designed to function at lower temps than air cooled engines. I use it regularly.
    Dec 2002
    Teton Valley, Idaho
    What would be the advantage to using 2 cycle oil over using a product designed specifically to lubricate injectors?
    I have a tech tip titled Duramax Injector failures that outlines my recommendations:
    http://www.kennedydiesel.com/docs/Du...20Failures.pdf
    Jan 2007
    Spokane Wa.
    Do you have to buy a whole case of total power fuel treatment?
    Jeff
    Quote Originally Posted by 9365turbo View Post
    We learned the hard way many years ago that shipping anything short of a nested case will result in a lost pkg. Not only do you lose the contents of the compromised container, but you also lose the entire contents of the pkg as a hazmat cleanup follows. We do have a mixed case available that is 1/2 TP and 1/2 8+ cetane if that helps. Many split with friends/family/neighbors etc. Shelf life is indefinite as well.
    If you 1x treat ratio at say 15 mpg average you'll get 45,000 miles from a case
    2x treat ratio will get you 27,500 miles from a case or you can choose a ratio in between
    Dec 2002
    Teton Valley, Idaho
    I've found FPPF Total Power at a local ranch supply store. It's about $18/quart, but it treats 250 gallons.
    Jan 2007
    Spokane Wa.
    I would pay off the truck before I would go through a cast of total power additive. So unfortunately a case just is way to much for me, but I understand your reasoning for only shipping a case. Thanks
    Jeff
    Jan 2007
    Spokane Wa.
    Which ranch supply?
    Jeff
    Dec 2002
    Teton Valley, Idaho
    CAL Ranch. Not sure if there's one close to Spokane or not though.
    Jan 2007
    Spokane Wa.
    Nope. Idaho falls. Thanks though.
    Jeff
    Jan 2007
    Spokane Wa.
    I emailed the local sales rep for FPPF products to see if it's available in Spokane. Kenworth sales on east Broadway has it. So you mix total power and 8+ Cetane 1-1 and add 1/8oz per gallon of fuel?
    Jeff
