It's important to check the preload - I replaced the box on my Ford E350, and it was WAY too tight. If you have a Hydroboost system, it needs to be bled; a quick check is to see how the brakes are - spongy or too much stroke, there's air. Typically, the Hydroboost is the high point in the system.
