Thread: 4L80E - Delay in Reverse Engagement
    Jul 2001
    Windsor,California
    Default 4L80E - Delay in Reverse Engagement
    Recently had the 4L80E (220k miles) in my 96 K2500 4x4 Pickup rebuilt by a recommended local Transmission Shop. Since getting the truck back, when shifting into reverse, there is a delay before engagement of approx 2-3 seconds. Took the truck back to them to be test-driven and they say it's a normal thing. The thing is, I don't recall the truck doing that in the previous 120k miles I drove it.
    1996 Silverado K2500 ECLB 6.5TD - 4L80E - 4.10 Diff
    Diamond Eye 4" Turbo-Back Exhaust
    Flowmaster Downpipe + Crossover Tube
    Lubrication Specialist SS Oil Cooler Lines
    9 Blade Fan and JK Fan Clutch
    JK Quick Heat Glow Plugs
    Heath PMD Isolator System
    Racor 645 Fuel Filter
    PML Deep Trans Pan
    Amsoil ATF
    K+N Air Filter
    Bilstein Shocks
    PYO Alloys
    2-3 seconds is a long lag, especially when the thing is warm.
    Jul 2001
    Windsor,California
    Any ideas on what the shop could have done to cause the issue?
    PML Deep Trans Pan
    Amsoil ATF
    K+N Air Filter
    Bilstein Shocks
    PYO Alloys
    Just to make sure - you’ve checked the fluid levels?
    Jul 2001
    Windsor,California
    Yes, have checked the trans fluid and it's where it should be.
    PML Deep Trans Pan
    Amsoil ATF
    K+N Air Filter
    Bilstein Shocks
    PYO Alloys
