Results 1 to 7 of 7
Thread: Turbo boost sensor
    Feb 2017
    Oregon, USA
    Default Turbo boost sensor
    Hi guys. First post. Having erratic throttle response. It is most pronounced when it is cold but what is happening is that when I accelerate while driving, it will race up to 2500 rpms then back down to 1400. This cycle will continue to occur all the way 30 minutes to work. I am a decent mechanic but had to take it in to have it scanned after I couldn't figure it out. Threw code p0238. I replaced the turbo boost sensor but it is still occurring. Any ideas?
    2000 Chevy K2500
    6.5 L TD
    256,000 Miles
    Replaced PMD @ 200,000, relocated to front bumper
    Manual Wastegate after vacuum pump quit
    New Lift Pump @ 250,000
    Regular schedule fuel filter replacments
    Sounds like a PMD/FSD issue to me. I've experienced erratic RPM control a few times, and it was always a PMD/FSD problem. If you've replaced that and it still acts up, probably an internal Injection Pump failure.
    Does it happen when using cruise control? If not, it could also be the Accelerator Pedal, but I doubt it.
    Feb 2017
    Oregon, USA
    Thanks for the reply. I believed the pmd failure would not have those symptoms. Just a no run condition. I wont rule it out though... It does have the same issues with cruise control on. Pedal checked out ok. Maybe a short in the wiring from the tbs to the pcm? The wiring gets lost in the harness bundle and hard to trace. Anyone know how to test the wiring?
    2000 Chevy K2500
    6.5 L TD
    256,000 Miles
    Definitely try the PMD first. Will probably save you a lot of headache.
    When mine has failed, it wouldn't hold a steady RPM, even on cruise control.
    The PMD failing typically results in a stall or no start condition, but can also fail to full throttle scenarios... which is quite scary. Unsteady RPM is also another symptom.
    Feb 2017
    Oregon, USA
    Okay you talked me into it! I suppose for whatever reason it wasn't the fix I'd still have a spare. Thanks.
    2000 Chevy K2500
    6.5 L TD
    256,000 Miles
    Feb 2017
    Oregon, USA
    Nope! The PMD was not it. Now I am thinking It may be the wiring between the sensor and the ecm. Thoughts anybody?
    2000 Chevy K2500
    6.5 L TD
    256,000 Miles
    Jan 2006
    Boissevain, MB., Canada
    Check all vacumn hoses attached to sensors and turbo.
    '95 GMC K2500, "Bullet"Ex. cab short.4X4, 377,000kl on truck, 177,000kl on AMG engine, auto. 3:73 Ltd. slip, FSD remote mount, OPS relay,AFE air IN, Kennedy 3 1/2" OUT . '83 F250 HD3/4 " Robert The Red Ford"4x4 460, 3:55'posi . 2005 GMC : G WHIZ" crew short box, 5.3, 4:10. , '88 Bronco II 4X4, '95 141,000kl Ford F150 EX. short box, '92 "Toy" 4 runner 273000kl ,'63 Mercury 45000miles !!!! Auto insurance co. is my mistress !!!
