TheDieselPage.com Forums
2018 - TDP's 22nd Anniversary
Go Back   TheDieselPage.com Forums > The Diesel Page Member Forums > 6.5L Turbo Diesel
6.5L Turbo Diesel 1992-00 6.5TD - Discussion forum for the 6.5L engine.
Reply
Thread Tools Display Modes
  #1
Old 11-14-2017, 08:06 AM
gsimpson gsimpson is offline
Enthusiast
Default Head rebuilding
OK I got great news the turbo side head came off and no block damage around the fire rings on the block. Also found my water leak where I was burning my coolant, very fixable. Pistons and bore are all in good shape.
So now I have new injectors, glow plugs and line kit coming and am going to build the new heads I bought. Also valve seals, going to re-use my valves and springs.
Torque specs on injectors was told 50 ftlbs and 15 ftlbs for the glow plugs.
Should I use anti-seize anywhere?
Ant advise or suggestions would be appreciated!
__________________
1995 Chevy 2500, 6.5L Diesel mostly stock 234,000 miles. Changed the water pump to HO WP, deleted the vacuum pump and added a mechanical wastegate controller made by me with info from others on the forum.
  #2
Old 11-14-2017, 05:58 PM
Robyn's Avatar
Robyn Robyn is offline
Missy Good Wench ( Moderator)
Anti seaze on the glow plugs and you could use it sparingly on the injector threads too.
Be sure the head bolt holes in the block are clean (run the proper metric tap through) then spray the threads with brakekleen and blow dry.
The head bolts have a dry silicone sealer installed out of the box.
The installation torque is a strange routine if you have not used the TTY bolts.
First pass 22 ft lbs (If I remember correctly) then 55 pounds through the entire pattern.. THEN 1/4 TURN MORE on all bolts through the torque pattern.
Bolts are not reusable.
Do not use any sealer on the FELPRO gasket or the bolts.
Have fun
__________________
(1) 95 Suburban 2500 4x4
(1) 2017 Mercedes C class
(1) 1997 Astro "CATVAN II"
  #3
Old 11-15-2017, 05:33 AM
Enthusiast
Thanks Robyn
__________________
Reply
Thread Tools
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
