Thread: please help
    Feb 2007
    La Porte, Texas
    Default please help
    Need help finding problem with 2001 LB7. The truck starts and idles fine but when the pedal is pressed, NOTHING. I have checked the fused and can't find the problem. Has happeded once before. Let sit overnight and problem went away. Any idea where to start?
    bayville, new jersey, USA
    did u change the fuel filter ? perhaps letting air in, or not primed up..
    had that problem once before, needed more pumps on primer on top of fuel filter.
    '12 gmc sierra 2500 dmax slt carbon black.
    '12 s350 diesel mb
    '10 mazda 6i, for sale
    '77 450sl benz, in family since new, sold, still in jersey thou
    '91 350sdl benz, 3.5l diesel, 28 mpg
    '90 560sel benz
    Oct 2003
    NW NJ
    check fuel petal and conections.
    This is all electronic...
    No Cables...
    maybe the conector came loose...
    1992 GMC Sierra("2003 TDP Photo Contest Winner") 6.5L Turbo Diesel, 4L80E Auto, 4x4, 3" Body Lift, 33"x12.5"x16.5" Tires, Back Country Nerf Bars, Banks Stinger Kit, Banks Pillar Pod, Banks Boost, Pyro, Trans Gauges, Kennedy Quick Heats, Lube Specialist Oil Lines cooler kit,
    2001 GMC Sierra EC K2500 6.6L 4x4 Duramax-Allison Long Bed, Predator 40hp program.
    Feb 2007
    La Porte, Texas
    Talking
    Problem was corrected today. I replaced the Pedal and the truck was still doing the same thing. I took it to the dealer and they hooked up to the computer which told them the pedal was bad. The one I put was only a day old and that is when the digging started. In the end the wire harness to the pedal had a bad wire which they replaced. The good thing is they only charged me $90.00 for two days of trouble shooting.
