Thread: Do it or leave it be dual filtration and or lift pump
    Jan 2017
    Western montana
    Default Do it or leave it be dual filtration and or lift pump
    I know this topic has probably been beat to death but I have
    been debating for awhile on whether to install dual filtration on my 01 duramax and possibly a lift pump or just leaving It alone. I just invested good amount of money into replacing injectors and want to protect my investment since I plan on keeping the truck for awhile.
    Adding a second fuel filter has too restrict fuel flow somewhat and I would think this might shorten the life of the fuel pump. Maybe a lift pump might solve any issue with fuel restriction maybe it's not something to worry about.
    The mechanic who installed my injectors said I would get better filtration without a lift pump because fuel is being pulled rather than pushed through the filter, but that I may get some more life out of the fuel pump.
    Any good info would be appreciated
    Dec 2002
    Teton Valley, Idaho
    Unless the fuel source is more than 30 feet or so below the pump, fuel IS being pushed through the fuel filter by atmospheric pressure. What a low pressure fuel pump WILL do is show leaks in the fuel lines up river of the high pressure fuel pump.
    Some would say you'd be better off installing a better water separator than the OEM system provides, especially if you live in a humid/rainy area and that water is what kills injectors. Of course, this is about as provable as any other school of thought.
    A high quality fuel supplement/lubricant, added to every tank of fuel, wouldn't hurt either.
    Loyal WI US
    Quote Originally Posted by silver89 View Post
    Protect your investment. Here is a Tech Tip that I wrote regarding the Duaramax Lift pump that should help.
    http://www.kennedydiesel.com/docs/Du...ift%20pump.pdf
    And another: http://www.kennedydiesel.com/docs/Du...ift%20pump.pdf
