Others can correct me if in error, but I believe the BR (balance rates) are from + to - 4.0 in park, + to - 6.0 in gear. PWM is your pulse width that is commanded by your ECM- tells the injector how long to stay open. A Tech II will give your those.
I had my head gaskets replaced about @ 340K and 60K later, one began leaking- exhaust was pressurizing my coolant system and blowing coolant out of the overflow reservoir. OEM head bolts may've been a contributor to this failure. As recommended by Kennedy, I bought a set of studs and had the dealership install them with a new set of gaskets. So far, no problems.
When I replaced my injectors last time, I used one of the feed pipes to rock the injector and pull it out. Replacing the feed tubes may not be a bad idea as any corrosion from within the big nut on the injector pipe will get into your injectors and ruin them.
I got my parts from GMPartsDirect.com. Their prices are just as good if not better (in some cases) than what I can get as a GM employee from the dealership! You'll get rebuilt Bosch injectors- none of them are "brand new".
"Chessy56"
So. Milwaukee, WI
'01 2500HD, LB7, ~440K miles
Winston Churchill
