There is a fuse in the convenience center under the hood on a 1995 that contains a 10amp fuse labeled for Glow Plugs. This fuse is only between the live power from the glow plugs and the actual bulb in the dash. Check this fuse.
Have a helper help you, have them turn the key while you check the voltage on the output of the controller to see that it's being signaled on and is doing so.
If so, it's the indicator lamp
1986 C10 SCLWB 6.2TD 3.73 700
1989 V20 SUB 6.2NA, 3.73 400
1994 G20 VAN 6.5NA, 3.42 60E
1996 K30 DRW 6.5TD 4.10 80E
