Results 1 to 20 of 26
Thread: Gear Drive vs Chain Timing Sets
    Arrow Gear Drive vs Chain Timing Sets
    Reprint from an article produced here in The Diesel Page in 2003
    Chains or Gears?
    Which is Best?
    6.5 Timing Set Pros & Cons
    What are the advantages and disadvantages of using a gear-drive timing set? Let's consider this question, and have a look at some of the related issues involving the 6.2/6.5 gear and chain timing sets.
    Three rumors we've heard about the gear-drive timing sets:
    #1 "Gear-drives contribute to broken crankshafts."
    Reality: A defective elastomer in a harmonic damper or torsional dampening crank pulley can result in a broken crankshaft. A broken cylinder block can result in a broken crankshaft. A defective flywheel or flexplate can result in a broken crankshaft. Knowledgeable mechanical engineers all agree that the purpose of the crankshaft mounted harmonic damper is to reduce harmful torsional vibrations that can and will fracture crankshafts if not controlled.
    (Added 6/1/09) Our own 6.5TD Power Project engine ran normally with a DSG gear drive timing set for more than 250,000 miles before it was sold in 2006. I believe weak cylinder blocks and/or defective dampers, pulleys or flywheels are the cause of broken crankshafts. Whether or not an individual vendor recommends a gear drive for the 6.5 depends on whether they sell it. It's that simple. The Diesel Page doesn't sell the gear drive nor does it sell any other part for your truck. The best and most reliable information is what we're interested in.
    #2 "The front end of the idler gear axle shafts rub destructively on the aluminum timing cover."
    Reality: When a gear drive timing set has been installed correctly, 6.2/6.5 engines that have been disassembled after running hundreds of thousands of miles all show that axle shaft rubbing on the aluminum front cover is of no concern.
    #3 "Gear-drive timing sets are noisy."
    Reality: My hearing might not be what it used to be, but after listening to at least a couple dozen 6.2/6.5 engines that were equipped with a DSG gear-drive, I have yet to detect any gear noise. The timing and camshaft advance produced by a gear-drive usually result in a more crisp combustion rattle. This should not be confused with gear noise. Whether or not one can detect any gear noise, it is just a small and insignificant contribution to the overall noise level produced by a running 6.2/6.5 diesel engine. You can hear the gear drive if you remove the oil filler cap on a running engine. I can't hear it otherwise.
    The factory original 6.5 timing chain set shown above produced about 5/8" (.625") of chain slack. The GM maintenance manuals specify a maximum of .800", while most new chains produce about .250" to .500" of chain slack. GM specifies .500" of chain slack as the maximum acceptable limit for a brand new chain. Obviously, there is a lot of variability.
    The 5/8" of chain slack shown in this photo produced about 3 degrees of crankshaft rotation before the gear bolted to the injection pump would begin to move (this equals approximately 3 crankshaft degrees of slop in the timing set). A chain with approximately .250" of slack produces about 2 degrees of crankshaft rotation, and a worn-out chain with .800" of slack will produce 4 degrees or more.
    The various timing gear sets I've installed have all produced approximately 2 degrees or less of crankshaft rotation, which in contrast to a chain, will change very little throughout the life of the engine. The primary advantages of a gear-drive timing set are: lower mass, built-in cam and injection pump advance (power & fuel economy improvements), more accurate fuel injection timing for the life of the engine with little to no change over time and miles (unlike a timing chain).
    Member Scott Boelman made the following report after installing a DSG Phazer gear-drive timing set:
    • "I carefully calculated my fuel economy during the 1588 miles prior to installing the Phazer kit. During this time, my truck averaged 16.9 mpg. In the 1758 miles since the installation, my fuel economy has improved to an average of 17.4 mpg. This is a 3% improvement in fuel economy. Driving conditions were similar for both test periods, primarily highway driving at 70 to 75 mph.
    • Power runs using full throttle can provide a good measure of engine power changes. However, acceleration testing a manual transmission equipped truck presents a slight problem in reproducibility. Minor changes in technique from one run to the next could produce big changes in elapsed time. To minimize driver error I ran the acceleration tests in 5th gear from an indicated 45 mph to 75 mph (similar to a passing acceleration test). Prior to the installation, a series of 45-75 mph 5th gear acceleration runs produced an average of 17.41 seconds. Following the Phazer installation, the average elapsed time was reduced to 16.96 seconds. This is an improvement of 0.45 seconds and translates into a 2.7 percent faster time."
    The 1982-84 6.2L diesel engines were equipped with stamped steel V-belt crank pulleys. GM introduced a torsional dampening crank pulley in the 1985 model-year in an effort to improve belt life and improve belt-driven accessory life. Anyone who has tried to keep V-belts on the 1982-84 6.2L engines know that unless kept exceedingly tight, wild gyrations are seen in the belts at idle or low engine speeds. Belt resonance is due to cylinder power impulses, which causes the crankshaft to slow down during each compression stroke, then accelerate on each power stroke.
    The same sort of harmonic resonance can occur with a loose timing chain. Resonating timing chains can cause all sorts of trouble. Aside from making it more difficult to accurately set the injection timing, loose timing chains can also result in sheared DS4 drive-head shear pins and loosened camshaft bolts - all due to high momentary torque loads caused by loose and resonating timing chains.
    The above image shows a mainshaft that had been removed from a DS4 electronic fuel injection pump. This pump (that the shaft was in) was pulled from service because the drive-head (pinned and bolted to the forward end of the shaft) had sheared the pin, and had begun rotating independently of the DS4 shaft. Obviously, the engine can't run when this happens. Aside from this shaft, I witnessed another occurrence of this problem at our local Chevy dealership a few years ago. The drive-head on that DS4 had sheared the pin and was somewhat loose on the pump shaft.
    Beginning about 1996, GM upgraded the cam bolt to a grade-10, and nearly doubled the camshaft bolt torque from 65 ft/lbs to 125 ft/lbs. A thread locking sealant is also now specified for the cam bolt, to help prevent it from loosening.
    The questions that beg an answer is why did these DS4 drive-head pins shear, and why did GM increase the camshaft bolt torque from 65 ft/lbs to 125 ft/lbs? One possibility is that loose timing chains can cause a harmonic resonance that creates high momentary torque loads on the cam and injection pump, resulting in sheared DS4 drive-head pins and loosened camshaft bolts.
    If a gear-drive timing set added torsional or impact stresses to the timing set and crankshaft, the problem with loose camshaft bolts and sheared injection pump drive-head pins would increase in frequency. As of 2006, our gear-drive equipped 6.5TD Project engine had accumulated over 250,000 miles without a problem of any kind, even though the camshaft bolt in this engine was torqued at the originally specified 65 ft/lbs.
    Depending on where you shop, a new chain/sprocket set could cost between $75 and $125. On the other hand, a gear-drive costs ~$250 (mechanically injected 6.2/6.5) to ~$350 for a Phazer gear-drive set made to operate with the electronic 6.5 fuel injection system. A gear-drive makes the most sense for the enthusiasts among us or for anyone who traditionally keeps the same vehicle for several years. If you tend to trade vehicles every 2-3 years, then a chain-drive timing set would make the most sense.
    TDP
    Sep 2007
    Jax Florida
    I have been looking for one of these, however I dont know where to buy them.
    I am looking for the cheapest I can find any ideas on where to buy the gear drive.
    93 GMC Sierra 2500
    6.5L TD Auto
    Quote Originally Posted by 93GMCSierra View Post
    Diesel Services Group (www.dieselservices.com) was the originator of the gear drive timing sets for the 6.2/6.5. At some point during the last few years, 6.2/6.5 gear drive timing sets have become available through a few national mailorder auto parts vendors - for less money. I don't have a link for one of them, but I'm sure someone else will post it. I don't know if there's a difference in gear drive design, fit or quality between the two sources.
    Sep 2007
    Jax Florida
    I found DSG on the advertisers page of all places huh
    They actually have the cheapest price of the ones I found. I am unsure if the $450+ is worth it. $225 or so as you listed it would be for sure. If I was doing a complete rebuild $450 might even be worth it but all I am planning is relocated new pmd, new "used" IP, new injectors, and glow plugs.
    at 195k for mileage and the serious lack of power and mileage this truck has I am guessing all the parts are original.
    I am getting many symptoms listed for these parts being worn. I keep getting a pump injector timing code. but its sporadic.
    Hard starting, 5 or more seconds of cranking, warm or cold. Cold starts are worse, lots of white smoke at start. Heavy diesel smell when starting and strong when running. I figure while I have it torn apart it probably needs a timing set. I will most likely get a new chain set. RockAuto has it for about $100.
    93 GMC Sierra 2500
    6.5L TD Auto
    Based on the symptoms you're reporting, a worn timing set could be a contributor. A new chain will likely help.
    DSG offers a gear drive for both the DB2 & DS4 equipped engines. If you have a 1982-1993 engine, you can use their standard "Dual Idler Gear Drive", which is about $100 less expensive than their "Phaser" gear drive, which includes a reluctor wheel for the crankshaft (that's why the increase in price).
    If you have an engine newer than 1994, you'll need the Phaser even if you are running a DB2. Or, you could machine a spacer to make up the difference for the thickness of the reluctor wheel. Or, install a damper made for a 1982-1993 engine.
    Sep 2007
    Jax Florida
    I still wish I had the 93. However this is the 97. Yes I am sure worn and excessive slack is a contributor.
    93 GMC Sierra 2500
    6.5L TD Auto
    Nov 2000
    Beltsville MD USA
    Take a look at Pete Jackson gear drives . Supposed to make them for DSG .
    A lot has changed since this post was last updated. Gear Drives were discontinued but now back in production. We try keep them in stock at all times as a US source for the DSG product.
    The hard starting with white smoke and such can also be caused by a set of worn out injectors.
    The occasional timing code is not a good sign though.
    The ECM will adjust the injection timing though a fairly broad range before it complains.
    Before spending the big $$$ for a gear set, I would suggest getting the Squirts checked.
    A strong diesel smell when warm is sign of bad injectors.
    If its a timing issue, the computer would complain bitterly.
    Hard cold starts, aside from bad glow plugs are directly connected to low pop pressure and a set of injectors that are Peeeeing a stream rather than a fine mist upon entering the injection cycle.
    This is a commonly overlooked problem which usually ends up with folks blaming the glow plugs.
    If your injectors are at 100K miles or more, they are suspect.
    With a set of squirts that are in good shape, these engines will start with minimal smoke even with half the glow plugs non functional.
    A long period of cranking followed by tons of white smoke and a period of time that the engine misses on a few holes, then followed by a strong pungent exhaust odor even when warm points more towards injectors than timing gears/chain.
    Having a timing set, either gears or chain and sprockets that's in good order is a plus for sure, and all the materials mentioned are definately spot on, I would still check your squirts before stepping up for the timing set.
    FWIW
    I have replaced chains on these and retained the original sprockets many many times. The sprockets are HARD and dont seem to wear.
    The chains stretch in time and as Jim mentioned, start to cause issues.
    I have seen engines with 250K miles and a chain that was looser than a rat tail in a rain barrel still run good without complaints.
    Missy
    Efland, NC, US
    I had a gear set on my old 6.2 engine that broke a crank (not bc of the gear set). I put a different 6.2 engine in the truck and installed a new gear set that a friend of mine bought for a 6.5. I bought a whole box of new/used parts from him when he sold his truck. The gear set was new and since mine had more than 200K on it I decided to put the new set in. It had the reluctor wheel with it but I didn't use it and I used my long snout balancer. Is there any difference in the gear set itself between the 6.5 and 6.2?
    Bill Efland
    83 C10 6.2TD Short Bed
    befland@yahoo.com
    Quote Originally Posted by befland View Post
    Not to my knowledge (other than cost). The reluctor added about $100 to the cost of the Phaser compared to the non-EFI gear set.
    That is correct. A gear drive is a gear drive. It becomes a phazer when you add the phazer ring. The injection pump type and the balancer snout length determine whether you need a phazer or not. The electronic balancers have a shorter snout so they would require a phazer to fill the void if used on a mechanical engine.
    Feb 2012
    Pauline, SC
    OK, let me get this all straight before I order the wrong thing, I am going with a GEP motor, ( ordered it today) a military take out 6.5, I have a DB2 pump, and will order a Fluidampr for a manual pump motor, and order a gear drive for a Manual motor ... am I right??
    Thanks, Chris
    1993 Chevy K3500
    like us on Facebook
    Thanks, Chris
    The Fluidampr produced for the mechanical fuel injection engines comes with a spacer to accommodate an installation with/without the reluctor. So, either way you'll be OK when using a mechanical gear set.
    Dec 2000
    Walla Walla WA
    Default Long term study of gears
    How has the long term use on these gear sets held up? Any long term tear down study conducted> I would be interested in seeing the condition of the gear teeth after 100k plus miles.
    Sep 2006
    Brooker, FL
    I have 90K on the factory (Peninsular Engines) AMG 6.5 TD. There was no sign of wear when I replaced the coolant pump at around 50K on the engine. These gears are VERY lightly loaded and in an oil bath, so wear should never be a concern.
    Aug 2014
    Abbotsford, Canada
    Quote Originally Posted by rustyk View Post
    Do you have a gear drive or chain? The chain is highly loaded as it drives the cam and IP. Mine has 250K on it and its scary loose.
    I want a gear drive so bad but $500 with exchange makes it a hard pill to swallow.
    1984 Chev Get-A-Way van, 6.2 diesel, remote mounted turbo built by me, running an HX35 turbo with a 60mm wheel. Burning WMO, WATF, jet fuel and Hydraulic oil.
    The DSG gear drives are no longer in production. We purchased the last of their stock and quickly sold out of the gear drive kits. We do still have some have phazer kits (just means extra parts for the mechanical guys) and when they are gone it will mark the end of an era.
    Feb 2006
    Miami, FL
    Unhappy
    Bad news for the 6.2/6.5 crowd. But then, the DuraMax was supposed to make these engines obsolete overnight . . . . NOT.
    Dr. Lee
    1984 C-10, custom 6.5L SAA, custom 700R4, Gone but NOT FORGOTTEN
    Default Gear Set
    I was told Leroys Diesel is making gear sets for these engines. I called and he claimed they are made in USA and are heat treated.
    FYI
