Results 1 to 2 of 2
Thread: Universal Fuel Filter Kit
    Greenfield, In
    Default Universal Fuel Filter Kit
    We now have our new Universal Fuel Filter Kit available. Two reasons we say that is is universal, 1) you can use many different brands of filters, so you are not stuck with just one brand of filter. 2)easy to hook up either pre or post OEM filter.
    Mounts where the second alternator would go, and will install in less than 30 minutes. Comes with a Baldwin 2 micron nominal filter, but Fleet Guard, Racor, Wix etc. can be used. Has bleeder screw on the clean side of the filter for easy priming or sample taking. Customer 9ga. steel powder coated bracket. Custom aluminum filter head designed not to trap air. Banjo fittings are utilized for a low profile professional looking setup. We use and OEM type covering over the hoses to prevent chaffing. Hose sized to fit exact on OEM fittings, so it’s not too tight or to loose. Best of all when installed it has that OEM look. Unit has over 60K miles of use in our own truck and 100K miles in another test truck with NO issues. Over 200 systems sold and has proven realiable.
    Order here now!
    Click on the link to view installation instructions http://www.lubricationspecialist.com/cmtdoc/uni.pdf
    Diesel Page Supporter
    Greg Landuyt
    Lubrication Specialist, LLC.
    1-888-306 4255
    greg@lubricationspecialist.com
    Greenfield, In
    We now have dealers buying them and installing them for their customers.
    Greg
    Greg Landuyt
    1-888-306 4255
