There is a lot of info on this site regarding timing of the 6.5. The one thing that I ran into was that the engine has to be up to I believe 185 degrees before the timing will take. I also remember that I had to sometimes increase the engine speed to get the setting where I needed it. Again I would suggest that you do a search on this site for timing of the 6.5 and you will get some great information.
