Results 1 to 2 of 2
Thread: Parts list for 2005 LLY head gaskets replacement
    Dec 2002
    Teton Valley, Idaho
    Default Parts list for 2005 LLY head gaskets replacement
    I know there's so much more than head gaskets that get replaced when the head gaskets get replaced...
    It seems there's a tiny fracture in one of my head gaskets (the coolant system gets pressurized and sometimes spits fluid from the overflow). There's no mixing of oil/antifreeze so right now I'm in the "refill the coolant as needed" mode and it's more of a nuisance than anything else BUT I know that I'm staring at a rather large bill if when the gasket really lets go. I was under the impression there may be a kit available with everything one needs to correctly complete the job (gaskets, probably go with the C size just to be sure, new generation torque to yield head bolts, valve cover gaskets, and I have no idea what else. Neither does the parts guy at the stealer, but of course he can get me anything I ask for. The service department wants over $5K to do the job, soup to nuts. A trusted local indy shop can do it for about $3K. I'm thinking that I can put in 40 hours plus <$1K for parts and do it myself... IF I know what parts to replace. Shouldn't need any milling - the engine has never gotten hotter than 210 indicated, so I don't think anything shoud be less than flat; a quick hit with 600 grit paper on a flat piece of steel should make the mating surfaces love each other again.
    Parts list? Then I'll save this thread for future reference unless a mod wants to make such parts list a sticky. Maybe call it the Parts List thread...
    Loyal WI US
    This should pretty much sum up one of our projects:
    Pr head gaskets grade C
    Set ARP head studs
    pr thermostats
    lower valve cover gaskets (optional)
    tube ultra gray
    exhaust manifold gaskets (optional)
    8 glow plugs (recommended)
    Return tee set for injectors (depends if any of yours break when removing)
    Surface heads with super skim cut then jet steam wash (wouldn't do it any other way)
    Coolant
    We keep pretty much all of this on hand.
