TheDieselPage.com Forums
2018 - TDP's 22nd Anniversary
Go Back   TheDieselPage.com Forums > The Diesel Page Member Forums > 6.5L Turbo Diesel
6.5L Turbo Diesel 1992-00 6.5TD - Discussion forum for the 6.5L engine.
Reply
Thread Tools Display Modes
  #1
Old 10-12-2017, 05:29 PM
Aftermath Aftermath is offline
Enthusiast
Default Fuel line diagram
I'm double checking my work, trying not to make any mistakes that will cost me in the long run
Does anyone have a fuel line/system diagram??
Thanks all! 😁
  #2
Old 10-12-2017, 06:42 PM
Robyn's Avatar
Robyn Robyn is offline
Missy Good Wench ( Moderator)
Two lines run from the tank to the engine bay.
Larger one is the feed from the tank to the fuel lift pump and then on to the engine fuel filter.
Smaller line is the return line back to the tank.
The return line is fed by a "manifold" (Well sort of) that picks up all the injectors and the return from the IP.
The incoming line feeds the filter and then from the filter on to the IP inlet.
The water drain /purge line goes from the bottom of the filter under the intake manifold to the water drain cock at the front of the engine and then drains to the ground when the cock is opened up.
Hope this helps
__________________
(1) 95 Suburban 2500 4x4
(1) 2017 Mercedes C class
  #3
Old 10-12-2017, 07:33 PM
Enthusiast
Hope this helps
Yep, awesome. Thanks for the help. I'm after it.
  #4
Old 10-13-2017, 07:42 AM
Robyn's Avatar
cool
__________________
Reply
Thread Tools
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
