mech199 welcome to the page.
A new post would probably be better.
Maybe one of the moderators could move this to a new post for you?
Do a little searching in old posts you might find what your looking for. Use the Search function at the top of the page.
Have you checked fuel shut off solenoid to see if it is working?
Leaks in fuel lines between tank and pump?
Do you have fuel at filter bleed with electric pump jumped? Pressure should be 3or 4 pounds off and can drop to 0 under throttle.
Only 3 tings needed on Diesels, fuel, air, and compression.
Lots of good help and info here.
What part of Kentucky are you in?
