TheDieselPage.com Forums
2017 - TDP's 21st Anniversary
Go Back   TheDieselPage.com Forums > Chevrolet & GMC 2500HD/3500 Light Trucks > 2500HD/3500 HD Trucks & Drivetrain
2500HD/3500 HD Trucks & Drivetrain Discussion Forum for the 2001 & newer 2500HD/3500 Trucks, Transmissions & Drivetrain
Reply
Thread Tools Display Modes
  #1
Old 08-05-2017, 04:10 PM
gary_lucas's Avatar
gary_lucas gary_lucas is online now
Enthusiast
Default Ball joint failed
I was poking around on the driver side finishing attaching the power steering line supports when i saw this:
https://goo.gl/photos/vs1BbabamzQgm3gWA
Thank god I noticed...
I pressed in a new moog ball joint a couple months back... I'm pretty sure it looked fine a week ago.
The ball joint is destroyed, the boot is literally shredded and shoved halfway through the control arm.
The control arm splines are deformed.
I'm going to blame myself, I pushed it in, I have never done it before and likely screwed it up.
Just wondering if anyone has insight for me? I'm also now worried because I did the other 3 ball joints... They still seem solid, I went down and checked each of them. Also, by the time I got to them I was a little more competent at being able to line them up properly. Has anyone else seen this?
Thanks!
I've purchased a new MOOG control arm and will install it tomorrow.
__________________
  #2
Old 08-07-2017, 09:56 PM
gary_lucas's Avatar
Enthusiast
Haven't installed the new arm yet...
I managed to tear something or stress a tendon or something of that nature. Waiting til that has stopped hurting for a day or two.
The other side still looks good.
https://goo.gl/photos/PqJotuLyvQvnTFLP7
Once I do the new control arm I'll take it for an alignment and then give it a good road test and re-inspect.
__________________
  #3
Old 08-13-2017, 01:02 PM
gary_lucas's Avatar
Enthusiast
New control arm installed.
The hardest bit was getting the bolts loose. I soaked them in honey goo + liquid wrench every night for a few days... And then after jacking up the control arm I got my small impact on the bolt and just zipped it back and forth for a few minutes (5 seconds tighten then 5 seconds loosen... Wait... Repeat).
Both bolts were loose in about 5 minutes. Last time I fought with these it took an hour and didn't get much done.
Those newer little electric impacts are awesome.
__________________
  #4
Old 08-13-2017, 05:58 PM
rapidoxidationman rapidoxidationman is offline
Enthusiast
Does the steering feel any tighter?
__________________
'85 Mercedes Benz 300D, for when I want to be stately.
'05 Mercedes E320 CDI, for when I want to be even statelier.
'05 Chevy K2500 ext cab long box DMax: Everything my '03 was and so much more!
There's no point being a pessimist - it wouldn't work anyway.
  #5
Old 08-14-2017, 11:11 AM
gary_lucas's Avatar
Enthusiast
Quote:
The truck is down to almost new again. The steering has maybe 1/2 an inch of play in it. probably less, it's not as tight as my B250, but it's not that far off.
I'm going to install the cognito kit this weekend if my arm co-operates.
My next project is fixing the body rust. I took the wheel well / mud flap off.
I'm pretty disgusted by the rust protection on these trucks. The fender flares and wheel well are poorly isolated. The whole back of the wheel well was loaded with rust and crap. You can't see it til you take the fender flare off.
If the fender flare wasn't there I don't think there'd be rust... IE I think the fender flare catches the water and crap and keeps it there.
__________________
Reply
Thread Tools
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
Copyright ©2000 - 2017, vBulletin Solutions, Inc.
Copyright 1996-2017 by TheDieselPage.com - All Rights Reserved
