Head gasket leak???
2001 LB7 with 333,338 miles. While doing a front end lube I noticed I've got some wetness near the #1 cylinder (front of engine, passenger's side). There's a streak of orange and dark (oil) mix seeping from what appears to be the mating surface between the head and the block. A check of my oil and coolant bottle shows that I was down a little on both- about a pint or so, which I added. I see a little smoke from the tail pipe when cold, but it smells more like diesel- so, I suspect I've got an injector or two that is staring to degrade. My initial plan is to take it to the dealership in the morning to confirm my suspicions, but perhaps some of the experts on this page can confirm my findings. The engine runs quiet, the oil is dirty (it's due for its periodic change) but I'm not seeing any foam in the oil. The engine surges a bit at idle when it's up to temperature, but my guess is that it's the FP regulator.
Head gasket going? If so, can anyone drop me a ballpark estimate on getting it replaced at the dealership? I wouldn't mind attempting this myself (can do with a good manual and any specialty tools required), but after reading some of the threads on this site I'm beginning to wonder if I'd be better off having a professional pound this out? Would the dealership have to pull the cab in order to do this or can this be done under the hood? Are replacement head studs really $800 for a set (or is that for both heads)? I'd rather have just the one side done now, as I'm still contemplating upgrading to a newer DMax (undecided). The driver's side appears dry/clean and I don't pull anything of substantial weight. It sees a lot of highway miles (about 600 a week).
Any comments appreciated!
"Chessy56"
So. Milwaukee, WI
'01 2500HD, LB7, ~440K miles
Winston Churchill
