Results 1 to 17 of 17
Thread: VIN check please
    Dec 2004
    Murphy, NC
    Default VIN check please
    Good evening - After visiting the RV show here in Tampa, we seem to be heading toward the need to upgrade our 2002 2500HD CCSB D/A which has served well and faithfully for 148K now to a model with more tires on the back. The potential new 5th wheel has too much pin weight to stay both safe and legal on the tires, so it is time to go to a dually. Could one of you folks look up the data and service record on 1GTJK33D87F115709 for us. We have started looking while still down in Florida helping at one of the state parks, and have found this one which looks pretty good and might fit the pocketbook.
    Thanks for any information you may be able to give.
    Don
    Dec 2004
    Maryland
    Default Here's the VIN report
    VIN : 1GTJK33D87F115709
    VEHICLE INFORMATION
    Merchandising Model : TK35943 -2007 SIERRA 3500 4WD CREW CAB SLT Warranty Start Date : 10/07/2006
    BARS Order Type : 70 - RETAIL - STOCK
    Delivering Dealer : JAMES RIVARD BUICK PONTIAC GMC
    PO BOX 3350
    BRANDON , FL 33509-3350
    (813) 620-3933
    Selling Source : 48 - GMC TRUCK
    Site Code : 08078
    Business Associate Code : 160846
    Service Contract : No Branded Title : No Warranty Block : No PDI Status : Paid
    REQUIRED FIELD ACTIONS
    Vehicle Has No Current Record Of Outstanding Campaigns
    SERVICE INFORMATIONAL ITEMS
    Vehicle Has No Current Record Of Outstanding Service Information
    ON STAR AND XM SATELLITE RADIO INFORMATION
    OnStar Equipped Yes OnStar Status Inactive Refer to Help page for details or:go to OnStar Online Enrollment (located on the "OnStar" tab in GM InfoNET) or (888)ONSTAR1 (888) 667-8271.
    XM Equipped Yes XM Radio ID JZ3WK08M XM Status Active Refer to Help page for details or: www.xmradio.gm.ca or Dealer Hotline 1.877.GET.XMST (1-877-438-9677).
    APPLICABLE WARRANTIES
    Description Effective Date Effective Odometer End Date End Odometer
    36/36000 BUMPER TO BUMPER LIMITED WARRANTY 10/07/2006 103 miles 10/07/2009 36103 miles
    72/100000 SHEET METAL COVERAGE RUST THROUGH LIMITED WARRANTY 10/07/2006 103 miles 10/07/2012 100103 miles
    60/100000 POWERTRAIN COVERAGE LIMITED WARRANTY 10/07/2006 103 miles 10/07/2011 100103 miles
    60/50000 FEDERAL EMISSION 10/07/2006 103 miles 10/07/2011 50103 miles
    60/100000 GM DIESEL ENGINE IN LIGHT DUTY VEHICLE LIMITED WARRANTY 10/07/2006 103 miles 10/07/2011 100103 miles
    CLAIM HISTORY
    R.O Date R.O Number Type Labor Operation Odometer Reading
    08/25/2006 218577 I Z6998 - PDI ADDS 5 miles
    08/14/2006 A15709 I Z7000 - PRE-DELIVERY INSPECTION - BASE TIME 0 miles
    Dec 2004
    Murphy, NC
    Smile
    Thanks very much GMC TECH - I am going to have to go back and take a closer look and give it a spin.
    Dec 2004
    Murphy, NC
    Default Follow-up
    Well, we liked it, so it is now towing our rig home while the 02 frisks along behind with no load. We had to get the dealer to reclaim it from the auction (we were about an hour too late to catch it on the lot). Seems to be in great shape other than no one had apparently ever checked the fluid levels in the gear cases - all were low but the engine and transmission were fine. Now has a B&W hitch in the bed (easy install, since someone had pulled out a DrawTite goosneck hitch and left a big rectangular hole in the bed) - the companion fifth wheel hitch hides that for now. I will have to get a piece of bed material and fix the remaining hole. Truck has a spray in liner, but at the dealer it also had a new plastic bed liner covering a white metal patch over the hole in the bed - probably what kept it on the lot - anyone looking at a truck with a plastic insert on top of a good spray in liner would have to ask why and look underneath! Also had a drawtite (timed ramp type) brake controller which we replaced with a Prodigy so our trailer disc brakes would be doing the right thing. We will be listing our 02 if a couple of local leads do not pan out.
    Observations so far - the dually actually rides less choppy due to the longer wheelbase, and the 6th gear in the Allison makes for less engine noise - the stiffer ratio is more than overcome with the increase in hp and torque compared to the 02, and it was no slouch. RV is an 02 Glendale Titanium 32E37DS, which is one of the light ones (less than 12k gross) - the pin weight is nothing for the dually, and wind resistance is a lot lower because of the snout on these RV's - you cannot really tell the difference with a headwind.
    Don
    Dec 2009
    VIN check please-
    1GCHK33GX6F152705
    Dec 2004
    Maryland
    Default Here you Go
    VIN : 1GCHK33GX6F152705
    VEHICLE INFORMATION
    Merchandising Model : CK35943 -2006 SILVERADO LT3 3500 4WD SRW CREW Warranty Start Date : 12/03/2005
    Delivering Dealer : GUARANTY CHEVROLET
    PO BOX 279
    JUNCTION CITY , OR 97448-0279
    (541) 998-2333
    Selling Source : 13 - CHEVROLET
    Site Code : 19195
    Business Associate Code : 114428
    Type Number Description Posted Date Status
    RC 06080 FUEL RAIL PULSE DAMPER RETAINER CLIP N/A Closed
    Vehicle Has No Associated On Star or XM Radio Information.
    36/36000 BUMPER TO BUMPER LIMITED WARRANTY 12/03/2005 24 miles 12/03/2008 36024 miles
    72/100000 SHEET METAL COVERAGE RUST THROUGH LIMITED WARRANTY 12/03/2005 24 miles 12/03/2011 100024 miles
    84/70000 CALIFORNIA SELECT COMPONENT 12/03/2005 24 miles 12/03/2012 70024 miles
    60/50000 CALIFORNIA EMISSIONS 12/03/2005 24 miles 12/03/2010 50024 miles
    CLAIM HISTORY
    11/27/2007 125688 # C6870 - PASSENGER SEAT CUSHION COVER REPLACEMENT 21186 miles
    11/01/2007 125124 # J3175 - LINE AND/OR HOSE, ENGINE OIL COOLER - PIPE ASSEMBLY - REPL 20709 miles
    11/01/2007 125124 # C6870 - PASSENGER SEAT CUSHION COVER REPLACEMENT 20709 miles
    11/01/2007 125124 # F1670 - SEAL, HUB OIL - REAR AXLE - RIGHT - REPLACE 20709 miles
    06/13/2007 121617 # B4661 - REAR SIDE DOOR LOCK REPLACEMENT - LEFT SIDE 16916 miles
    02/05/2007 118405 # H2820 - CABLE AND HANDLE ASSEMBLY, PARKING BRAKE RELEASE - R&R OR 13308 miles
    02/05/2007 118405 # Z5001 - VIP FREIGHT/POSTAGE REIMBURESEMENT 13308 miles
    12/12/2006 117100 # J0667 - DRIVE BELT REPLACEMENT - ACCESSORY 11801 miles
    11/21/2006 116595 # J0680 - TENSIONER, PRIMARY ACCESSORY DRIVE - REPLACE 10769 miles
    10/16/2006 115766 # J0660 - BELT, SECONDARY ACCESSORY DRIVE - REPLACE 9814 miles
    10/09/2006 115612 # V1506 - 06080 - REPLACE ENGINE FUEL RAIL PULSE DAMPER RETAINER CLI 9302 miles
    10/09/2006 115612 # E8360 - POWER STEERING PUMP PULLEY REPLACEMENT 9302 miles
    07/24/2006 113681 # E8360 - POWER STEERING PUMP PULLEY REPLACEMENT 6800 miles
    05/24/2006 164948 # J0680 - TENSIONER, PRIMARY ACCESSORY DRIVE - REPLACE 4969 miles
    04/25/2006 163946 # C2745 - CUP HOLDER, CONSOLE - FRONT AND/OR REAR - REPLACE 3920 miles
    04/10/2006 163435 # J0660 - BELT, SECONDARY ACCESSORY DRIVE - REPLACE 3590 miles
    11/09/2005 107563 I Z6998 - PDI ADDS 3 miles
    10/24/2005 A52705 I Z7000 - PRE-DELIVERY INSPECTION - BASE TIME 0 miles
    Jan 2007
    Spokane Wa.
    Could you give me a Vin check? 1gthk23112f168467 Thanks
    Jeff
    Dec 2004
    Maryland
    Default Here you go.
    VIN : 1GTHK23112F168467
    VEHICLE INFORMATION
    Merchandising Model : TK25943 -2002 SIERRA 2500 HD 4WD CREW CAB Warranty Start Date : 03/11/2002
    Delivering Dealer : GRIMES MOTORS
    PO BOX 6549
    HELENA , MT 59604-6549
    (406) 442-5810
    Site Code : 18086
    Business Associate Code : 119010
    RC 04007 TAILGATE SUPPORT CABLE N/A Closed
    RC 05546 15,000 MILE - 24,000 KM FUEL FILTER CHANGE **IN EFFECT UNTIL SEPT. 30, 2006** N/A Closed
    SB 06048 ONSTAR H/W IS ANALOG ONLY-CANNOT BE UPGRADED TO DIGITAL-SEE TSB 06-08-46-007 01/23/2007 See Bulletin
    XM Equipped No XM Radio ID N/A XM Status N/A Refer to Help page for details or: www.xmradio.gm.ca or Dealer Hotline 1.877.GET.XMST (1-877-438-9677).
    36/36000 BUMPER TO BUMPER LIMITED WARRANTY 03/11/2002 82 miles 03/11/2005 36082 miles
    72/100000 SHEET METAL COVERAGE RUST THROUGH LIMITED WARRANTY 03/11/2002 82 miles 03/11/2008 100082 miles
    60/100000 FEDERAL EMISSION 03/11/2002 82 miles 03/11/2007 100082 miles
    60/100000 GM DIESEL ENG IN LD VEH WITH $100 DEDUCT AFTER BUMPER TO BUMPER LIMITED WARRANTY 03/11/2002 82 miles 03/11/2007 100082 miles
    CLAIM HISTORY
    02/03/2007 052089 # V1242 - 04007 - INSPECT AND REPLACE TAILGATE SUPPORT CABLES INC. H 127093 miles
    02/24/2006 212511 # V1380 - 05546 - REPLACE FUEL FILTER 99533 miles
    08/11/2004 164377 F Z7200 - CORPORATE PARTS RETURN REIMBURSEMENT 62746 miles
    08/11/2004 164377 # T5603 - 04039 - REPLACE ALL 8 FUEL INJECTORS - REFER TO TSB 04-06- 62746 miles
    06/25/2003 150119 # A2610 - PICKUP BOX FRONT END PANEL REFINISH/CLEAR COAT - INTERIOR 27700 miles
    05/02/2003 148336 # K5228 - SWITCH, PARK/NEUTRAL POSITION - REPLACE 23984 miles
    05/02/2003 148336 # K5364 - TRANSMISSION CONTROL MODULE REPROGRAMMING WITH SPS 23984 miles
    02/05/2003 100831 # F1441 - OUTPUT SHAFT SEAL REPLACEMENT - LEFT SIDE 19283 miles
    02/05/2003 100831 # N0528 - BULBS, LAMP - EXTERIOR - REPLACE 19283 miles
    02/05/2003 100831 # B9660 - UNDERHOOD LAMP REPLACEMENT 19283 miles
    09/03/2002 045576 # B5795 - BEZEL, TAILGATE/ENDGATE OUTSIDE HANDLE - REPLACE 12917 miles
    08/21/2002 045038 # B5820 - STRIKER AND/OR SUPPORT, TAILGATE LOCK - RIGHT - REPLACE 12052 miles
    08/21/2002 045038 # B5880 - ROD AND/OR LATCH, TAILGATE LOCK - R&R OR REPLACE 12052 miles
    04/16/2002 039762 # B9640 - LAMP ASSEMBLY, EXTERIOR - STOP, TAIL AND TURN SIGNAL - RIG 3147 miles
    04/16/2002 039762 # J6355 - POWERTRAIN CONTROL MODULE TRANSMISSION REPROGRAMMING WITH 3147 miles
    01/04/2002 A68467 I Z7000 - PRE-DELIVERY INSPECTION - BASE TIME 0 miles
    Jan 2007
    Spokane Wa.
    Thanks alot.
    Jeff
    Dec 2009
    could you please run a VIN and also run a build sheet for 1GTHK29D27E148520
    Much appreciated
    Dec 2004
    Maryland
    VIN : 1GTHK29D27E148520
    VEHICLE INFORMATION
    Merchandising Model : TK25953 -2007 SIERRA 2500 HD 4WD EXT CAB SLE1 Warranty Start Date : 02/17/2007
    Delivering Dealer : ALPINE MOTORS CO., INC.
    PO BOX 336
    SANDPOINT , ID 83864-0336
    (208) 263-2118
    Site Code : 18015
    Business Associate Code : 116703
    36/36000 BUMPER TO BUMPER LIMITED WARRANTY 02/17/2007 755 miles 02/17/2010 36755 miles
    72/100000 SHEET METAL COVERAGE RUST THROUGH LIMITED WARRANTY 02/17/2007 755 miles 02/17/2013 100755 miles
    60/100000 POWERTRAIN COVERAGE LIMITED WARRANTY 02/17/2007 755 miles 02/17/2012 100755 miles
    60/50000 FEDERAL EMISSION 02/17/2007 755 miles 02/17/2012 50755 miles
    60/100000 GM DIESEL ENGINE IN LIGHT DUTY VEHICLE LIMITED WARRANTY 02/17/2007 755 miles 02/17/2012 100755 miles
    CLAIM HISTORY
    01/28/2009 101727 # K9529 - TRANSMISSION FLUID COOLER UPPER PIPE ASSEMBLY REPLACE 29900 miles
    01/28/2009 101727 # E8047 - STEERING LINKAGE INNER TIE ROD REPLACEMENT - BOTH SIDES 29900 miles
    01/28/2009 101727 # J3523 - ENGINE COOLANT HEATER CORD REPLACEMENT 29900 miles
    12/27/2007 081278 # H1320 - POWER BRAKE BOOSTER REPLACEMENT 12066 miles
    12/27/2007 081278 # Z5000 - DEALER/RETAILER TRADE(PART OBTAINED LOCALLY) 12066 miles
    12/27/2007 081278 # E7700 - SHAFT, STEERING INTERMEDIATE - REPLACE 12066 miles
    03/16/2007 077704 # R0760 - RADIO, REMOVE AND REPLACE 1090 miles
    03/16/2007 077704 # J0667 - DRIVE BELT REPLACEMENT - ACCESSORY 1090 miles
    02/28/2007 077704 # R0754 - RADIO RECEIVER-RETURN TO AC/DELCO ESC 1090 miles
    09/22/2006 A48520 I Z7000 - PRE-DELIVERY INSPECTION - BASE TIME 0 miles
    Dec 2004
    Maryland
    Default Heres the build sheet
    VIN 1GTHK29D27E148520
    VEHICLE BUILD
    Gross Vehicle Weight Rating : 4177 kg (9210 lb) Order Number : KJCFQJ
    Build Date : 09/22/2006 Build Plant : 17E53
    GMVIS is not the definitive source of GM Vehicle RPO information and is intended for service reference only. Should there be any questions about the vehicle's original build or RPO information please refer to the original vehicle invoice or window sticker.
    OPTION CODES
    AE7 - UPLEVEL 40/20/40 FRT SPLIT BENCH SEATS - CUSTOM CLOTH AG1 - POWER DRIVER SEAT ADJUSTER
    AJ1 - DEEP TINTED GLASS AM7 - FOLDING REAR SEAT
    AU0 - REMOTE KEYLESS ENTRY SYSTEM AU3 - POWER DOOR LOCKS
    A31 - POWER WINDOWS B30 - FULL COLOR-KEYED CARPET W/MATS
    B32 - FRONT COLOR-KEYED FLOOR MATS B33 - REAR COLOR-KEYED FLOOR MATS
    B71 - WHEEL FLARES B85 - BRIGHT BODYSIDE MOLDINGS
    CJ3 - DUAL ZONE AIR COND - MANUAL C49 - ELECTRIC REAR WINDOW DEFOGGER
    C6W - GVW RATING - 9,200 LBS DF5 - AUTO-DIMMING ISRV MIRROR WITH COMPASS & TEMP
    DK7 - OVERHEAD CONSOLE DPN - PWR HTD EXT CAMPER MIRRORS W/ TURN SIGNAL & LWR CONVEX GLASS
    E63 - WIDESIDE BOX PICKUP BED FE9 - 50-STATE EMISSIONS
    FT2 - ARM TORS BAR SPRING ADJ FT3 - ARM TORS BAR SPRING ADJ
    GMC - ASSEMBLY PLANT-PONTIAC EAST GT4 - REAR AXLE, 3.73 RATIO
    G80 - H.D. RR AUTO LOCK DIFFERENTIAL HVY - IDEN 2 INCH BODY RAISE,HD MODEL
    JH6 - 4 WHEEL POWER DISC BRAKES, HD KC4 - ENGINE OIL COOLING SYSTEM
    KG3 - ALTERNATOR 145 AMP KNP - H.D. TRANSMISSION OIL COOLER
    KUP - THROTTLE CONTROL ELECTRONIC K05 - ENGINE BLOCK HEATER
    K34 - CRUISE CONTROL K47 - HIGH CAPACITY AIR CLEANER
    LBZ - DURAMAX 6.6L V8 TURBO DIESEL ENG - 360HP, 650LB-FT TORQUE MW7 - ALLISON 1000 6-SPEED AUTO TRANS
    NP1 - ELECTRONIC TRANSFER CASE NP5 - LEATHER-WRAPPED STEERING WHL
    NT9 - EMISSION SYSTEM FEDERAL, TIER 2 PHASE-OUT PDN - HEAVY DUTY POWER PACKAGE INCL: *DURAMAX 6.6L TURBO DIESEL V8 ENG-360HP, 650 LB-FT TORQUE *ALLISON 1000 6-SPD AUTO TRANS *H.D. RR AUTO LOCKING DIFF
    PY0 - POLISHED ALUMINUM WHEELS QIZ - LT245/75R16/E ALS BW TIRES
    R6K R6P - PRICE LABEL PAINT CHARGE
    R8C - ******************************* ***** 2007 CLASSIC SIERRA ***** ******************************* R9N - LEATHER SEAT TRIM
    R9Z - POMS EXPEDITE-SOLD ORDERS SAF - SPARE TIRE LOCK
    SLM - STOCK ORDERS TFE - SALES INCENTIVE-COMMITMENT PLUS
    TQ3 - BATTERY 770 CCA (DUAL) T96 - FRONT FOG LAMPS
    UB0 - AM/FM STEREO W/CD PLAYER (REPLACES STD/OPT RADIO) UK3 - STEERING WHEEL RADIO CONTROLS
    UQ3 - ENHANCED AUDIO SPEAKER SYSTEM VB3 - CHROME STEP REAR BUMPER
    VG3 - CHROME FRONT BUMPER VK3 - FRONT LICENSE PLATE MOUNT
    VR4 - WEIGHT DIST HITCH PLATFORM VXS - COMPLETE VEHICLE LABEL
    V22 - CHROME GRILLE SURROUND V73 - STATEMENT OF CERT. U.S.
    XHH - FRONT TIRE, ALL SEASON YD3 - BASE EQUIP FOR SCH GVW PLATE
    YD5 - FRONT SPRING - BASE EQUIPMENT YD6 - REAR SPRING - BASE EQUIPMENT
    YE9 - SLE/SLT DECOR YHH - REAR TIRE, ALL SEASON
    ZHH - LT245/75R16/E ALS BW TIRE-SPR ZY1 - SOLID PAINT
    Z82 - H.D. TRAILERING EQUIPMENT PKG. Z85 - HANDLING/TRAILERING SUSP PKG
    Z88 - GMC TRUCK NAMEPLATE 1SZ - HD PWR PACK SAVINGS
    16U - STEEL GRAY METALLIC 3SA - SLE1 DECOR INCLUDES: *AUTO-DIMMING ISRV MIRROR WITH COMPASS & TEMP *ELECTRIC REAR WINDOW DEFOGGER *DEEP TINTED GLASS *AM/FM STEREO W/CD PLAYER *CRUISE CONTROL *POWER LOCKS & WINDOWS *REMOTE KEYLESS ENTRY SYSTEM *POWER HEATED EXTERIOR BLACK MIRRORS *LEATHER-WRAPPED STEERING WHEEL *CHROME-STYLED STEEL WHEELS *BODYSIDE MOLDINGS
    6GL - SPRING COMPTR SELECT FRT LH 69D - DARK PEWTER
    69I - DARK PEWTER INTERIOR TRIM 7GL - SPRING COMPTR SELECT FRT RH
    Feb 2010
    San Diego, CA (Iraq)
    One more request!?
    First post, and possibly the first purchase of a diesel. Would really appreciate a VIN check and Build sheet for: 1GTHC24133E178727
    Many thanks!!
    Ross
    Dec 2004
    Maryland
    Default Heres the Vin report
    VIN : 1GTHC24133E178727
    VEHICLE INFORMATION
    Merchandising Model : TC25903 -2003 SIERRA 2500 HD 2WD REG CAB PKUP Warranty Start Date : 11/14/2002
    BARS Order Type : 60 - RETAIL - SOLD
    Delivering Dealer : RUDDELL AUTO MALL
    PO BOX 370
    PORT ANGELES , WA 98362-0058
    (360) 452-6822
    Site Code : 40029
    Business Associate Code : 116729
    36/36000 BUMPER TO BUMPER LIMITED WARRANTY 11/14/2002 10 miles 11/14/2005 36010 miles
    72/100000 SHEET METAL COVERAGE RUST THROUGH LIMITED WARRANTY 11/14/2002 10 miles 11/14/2008 100010 miles
    60/100000 FEDERAL EMISSION 11/14/2002 10 miles 11/14/2007 100010 miles
    60/100000 GM DIESEL ENG IN LD VEH WITH $100 DEDUCT AFTER BUMPER TO BUMPER LIMITED WARRANTY 11/14/2002 10 miles 11/14/2007 100010 miles
    CLAIM HISTORY
    04/05/2007 025370 # Z2137 198763 miles
    02/19/2007 024479 # Z2132 193445 miles
    03/07/2006 018756 F Z7200 - CORPORATE PARTS RETURN REIMBURSEMENT 99843 miles
    02/20/2006 018468 # T5603 - 04039 - REPLACE ALL 8 FUEL INJECTORS - REFER TO TSB 04-06- 99842 miles
    02/20/2006 018468 # J5560 - FUEL PRESSURE REGULATOR REPLACEMENT 99842 miles
    01/11/2005 011515 # V1242 - 04007 - INSPECT AND REPLACE TAILGATE SUPPORT CABLES INC. H 94113 miles
    11/11/2003 004509 # D0362 - HEATER AND AIR CONDITIONING CONTROL REPLACEMENT 45763 miles
    11/11/2003 004509 # N0520 - READING LAMP BULB REPLACEMENT 45763 miles
    07/25/2003 002579 # N2116 - SWITCH - SWITCH MODULE, FRONT DOOR - RIGHT - REPLACE 32083 miles
    07/25/2003 002579 # C0182 - FRONT SIDE DOOR WINDOW REGULATOR REPLACEMENT - RIGHT SIDE 32083 miles
    02/17/2003 102343 # N2116 - SWITCH - SWITCH MODULE, FRONT DOOR - RIGHT - REPLACE 12220 miles
    02/17/2003 102343 # J6015 - SEPARATOR, OIL/AIR - REPLACE 12220 miles
    02/17/2003 102343 # H0137 - REAR BRAKE ROTOR REPLACEMENT - BOTH SIDES 12220 miles
    10/31/2002 A78727 I Z7000 - PRE-DELIVERY INSPECTION - BASE TIME 0 miles
  15. #15
    Dec 2004
    Maryland
    VIN 1GTHC24133E178727
    VEHICLE BUILD
    Gross Vehicle Weight Rating : 4177 kg (9210 lb) Order Number : FQVBD8
    Build Date : 10/31/2002 Build Plant : 13E03
    OPTION CODES
    AE7 - BENCH SEAT-UPLEVEL CUSTOM CLOTH AJ1 - DEEP TINTED GLASS
    A31 - POWER WINDOWS BG9 - FULL FLOOR RUBBER COVERING
    B71 - WHEEL FLARES B85 - BLACK BODYSIDE MOLDINGS
    CJ3 - AIR COND., DUAL ZONE MANUAL C49 - ELECTRIC REAR WINDOW DEFOGGER
    C6W - GVW RATING - 9,200 LBS DF5 - ISRV MIRROR W/COMPASS & TEMP
    DK7 - CUSTOM INTERIOR ROOF CONSOLE DL8 - HEATED POWER ADJ EXTERIOR MIRRORS
    E2C - ORDER TO DELIVERY - EXPEDITE E63 - WIDESIDE BODY
    FE9 - FEDERAL/NY/VT EMISSIONS FT2 - ARM TORS BAR SPRING ADJ
    FT3 - ARM TORS BAR SPRING ADJ GMC - ASSEMBLY PLANT-PONTIAC EAST
    GT4 - REAR AXLE - 3.73 RATIO G80 - LOCKING REAR DIFFERENTIAL
    HVY - IDEN 2 INCH BODY RAISE,HD MODEL JH6 - 4 WHEEL POWER DISC BRAKES, HD
    KC4 - ENGINE OIL COOLING SYSTEM KNP - H.D. TRANSMISSION OIL COOLER
    K34 - ELECTRONIC SPEED CONTROL K47 - HIGH CAPACITY AIR CLEANER
    K68 - ALTERNATOR 105 AMP LB7 - 6.6 L DURAMAX DIESEL
    M74 - 5 SPD AUTO TRANS, ALLISON NF2 - FEDERAL EMISSION SYSTEM
    NP5 - LEATHER WRAPPED STEERING WHL PDP - FULL FLOOR RUBBER COVERING
    PY2 - CHROME PLATED STEEL WHEELS P03 - CHROME WHEEL CENTER CAPS
    QIZ - LT245/75R16/E ALS BW TIRES R9Z - POMS EXPEDITE-SOLD ORDERS
    SLL - SOLD ORDERS TFE - SALES INCENTIVE-COMMITMENT PLUS
    TQ3 - BATTERY 770 CCA (DUAL) UB1 - AM/FM STEREO W/CD, CASSETTE
    UQ3 - ENHANCED PERFORMANCE SPEAKERS UY2 - WIRING PROVISIONS FOR CAMPER
    VB3 - CHROME REAR BUMPER VG3 - CHROME FRONT BUMPER
    VK3 - FRONT LICENSE PLATE MOUNT VP6 - NOISE CONTROL
    V10 - WINTER COVER V22 - CHROME GRILLE SURROUND
    V73 - STATEMENT OF CERT. U.S. V76 - RECOVERY HOOKS
    XHH - LT245/75R16/E ALS BL TIRES YD3 - BASE EQUIP FOR SCH GVW PLATE
    YD6 - REAR SPRING - BASE EQUIPMENT YE9 - SLE/SLT DECOR
    YHH - LT245/75R16/E ALS BW TIRES-REAR ZHH - LT245/75R16/E ALS BW TIRE-SPR
    ZY1 - SOLID PAINT Z82 - HEAVY DUTY TRAILERING EQUIPMENT
    Z85 - HANDLING/TRAILERING SUSPENSION PACKAGE Z88 - GMC TRUCK NAMEPLATE
    1SC - SLE DECOR INCLUDES: AIR COND., DUAL ZONE MANUAL CRUISE CONTROL REMOTE KEYLESS ENTRY W/ALARM POWER WINDOWS & DOOR LOCKS AM/FM STEREO W/CD REAR WINDOW DEFOGGER POWER HEATED OUTSIDE MIRRORS DEEP TINTED GLASS ISRV MIRROR W/COMPASS & TEMP 1SZ - OFF-ROAD PKG DISCOUNT
    50U - SUMMIT WHITE 6GK - SPRING COMPTR SELECT FRT LH
    69D - DARK PEWTER CUSTOM CLOTH 69I - DARK PEWTER INTERIOR TRIM
    7GK - SPRING COMPTR SELECT FRT RH
  16. #16
    Feb 2010
    Perfect. Thanks for the help!!
  17. #17
    Apr 2004
    Columbia, SC
    I would like a vin check just to see what is says. I have a 2002 GMC cc/sb d/a I bought in may 2003 used and it is running fine except for a little idle surge with about 123000 miles.
    VIN 1GTHK23132F227275
    Thanks
    2002 GMC 2500HD D/A CC SB 4x4 pewter, Rhino Liner, Cam-Locker Side Boxes, Bilsteins, Edge Juice<br />2005 Yamaha Rhino
