Originally Posted by
DmaxMaverick
This looks innovative and intriguing. Definitely an advantage for a trailer rental service and the like. $300USD isn't bad for a good setup (with minimal/no installation required). It appears to be intended for permanent installation to a single trailer (the hand-held device is married to the controller), but it could be temporary-mounted to any multiple of trailers. The more I look at this, the more I like it. I'd like to find more feedback in regards to function and reliability, though (not much available).
It's been around for a few years now, but I haven't had much experience with it myself. I know it's a good product (essentially their Prodigy technology mounted on the frame of the trailer).
