In the large wire bundle (black plastic conduit) that is going to the fuse/relay center at the aft, port side of the engine compartment... look for a 16-ish gauge, red wire with a black, female spade connector. It might already be "poking out" of the conduit. That's the wire you're looking for. Just apply +12V to it.
