Question on compression numbers
just wondering what the ranges are for the 6.2l as far as what psi is considered poor, fair, good, and excellent. I'm going to buy a compression tester tomorrow and test my compression. I have a engine that likes to crank a lot before starting, about 4 to 9 sec if she has not sat for a while. if she sat for a day or two then all bets are off sometimes 3 to 5 glow plug cycles with 10 to 15 sec start times. I have added the bypass for the glow plug system
1986 K5 Blazer (Restoration in progress): stage II racing "K" transmission with +4 quart pan, Banks turbo, new GP’s, 3rd rebuilt IP, Rebuilt injectors, Stud Grille, Aluminum Radiator, Halogen light upgrade, fog lights, and added factory Cruise and rear power window
1996 GMC Suburban K2500 6.5l diesel (Restoration in progress). Running on a DB2 IP, new GP’s, rebuilt injectors, rebuilt transmission with +4 quart pan, dibble din GPS radio, USB and 12v charging in the door pullers, Chasing down the wire gremlins at the moment.......
I think I’m a glutton for punishment
