Thread: Allison shutter
    Feb 2009
    Tucson, AZ
    Default Allison shutter
    My transmission in my 08 2500HD will shutter from a dead start just after the tires start to roll. It only happens from a dead start, not any other time. If I hook up my 5th wheel, it amplifies it by 5-6 times as worse.
    It's a 2008 with 9850mi. on it. It's been in the dealer for a week and a half. They re-shimmed the rear end, to no avail. It's still the same.
    I really don't know what they did, I told them to fix it and call me when it was done. I'm not upset, pissed, or angry in any way.
    Anybody else had/heard/seen this problem?
    Please email me at debtanker@msn.com please, I need to get this fixed, it's dune season and I'm getting a sand rail soon.
    Thanks folks,
    BBTank
    Dec 2000
    Hawaii/Arizona
    Default Allison Shutter
    BigBlockTank,
    My 2006 D/A, CC has had a shutter since day one. It gets worse with the 5th wheel in tow. I have checked the two-piece driveshaft U-joint timing, the U-joints and the driveshaft carrier bearing and they are all good. I finally decided that it is caused by the two-piece driveshaft. I once owned a 1968 Chevy truck with a two-piece driveshaft that had a shutter; when I installed a one-piece driveshaft the shutter went away. I later had that thought reinforced by a thread here at TDP. Aparently, there is a GM service bulletin on the Allison transmission shutter. The bulletin requires replacing the two-piece driveshaft with a monster one piece driveshaft. Do a search on the TDP and I am sure you will find some good information on the issue to pass onto the GM Service Tech.
    Good Luck,
    John
    *2007 Pontiac Solstice.
    Feb 2009
    Tucson, AZ
    Beside THANK YOU, all I can say is......I'll be damned. I told them idiots to check that, check for that, and last, check the trans data collection. So, I guess I was on the right track. HAHAHAHAHAHA, wait till I find this and shove it up their noses. I'll be on visit #3 for the same problem. In a lemon law state (AZ), that means buy it back from me!!!!
    Thanks again,
    BBTank
