Results 1 to 20 of 123
Thread: Smaller diesel engine, that would replace a gas inline four?
Hybrid View
    Jun 2008
    Quote Originally Posted by AKMark View Post
    Diesel engines are getting harder to find in the yards as their demand is gaining with the folks making their own Bio with the high fuel prices.
    That's why I still think a 6.2L is a great choice. It'll fit in the 350 convert kit, you can run the stock rear if you don't tow, offroad, or put a turbo on it. It weighs around 700 lbs, a bit heavy, but doable.
    I know many 6.2L's above 300K and running strong. Parts are another fun thing. While the Jetta motor would be smaller and probably give far better efficiency, the initial cost of getting the motor would be much higher me thinks and if you would have to rebuild it, I bet it will cost more. I could be wrong, but look up the costs to have a foreign motor rebuilt. INSANE!!!
    Plus this is a 6.2/6.5/6.6 site. Gotta promote what we work on!
    I missed your post last night..
    I'll make some calls around here. How much would a 6.2L used be worth, probably with 200-300K on the clock? What else would I need to make the swap other than mounts and stuff. Engine, trans...
    Oh, and the hydro boost, what is that exactly?
    Dec 2006
    North Pole, Alaska
    Quote Originally Posted by Gearstix View Post
    Diesel motors (for the most part) do not create vacuum like a gas motor so a vacuum powered brake booster won't work with one. Hydroboost uses a line from the power steering pump to power the brakes. You can get this out of any diesel truck, one ton truck and Astro van's use this. It's really easy to convert it.
    You will need a larger radiator, if you go with an auto, get a good cooler for it as well. A RV size cooler is only $75 at Napa.
    If you can get a donor vehicle, you will get everything you need. If you get the motor on it's own, don't forget the alternator, PS pump, A/C compressor (if equipped), starter (these are spendy), and intake box. These parts are not cheap if you buy them on thier own. If the motor has an A/C compressor, it's not hard to set it up with your current system so you keep your A/C.
    Don't forget that after you install your new motor and trans, you will probably have to get a driveshaft as your current one will probably not be the proper length. Having yours modified to fit shouldn't cost more than $300 and if you are lucky will cost closer to $140. A new one shouldn't be more than $400 and depending on the shop might be even cheaper than resizing yours.
    Your current guages will probably not work with this motor as your ECM will probably be wondering why the injectors and O2 sensors are. I would consider pulling the dash and replacing with aftermarket guages, or at least pull the check engine light and that way it doesn't tick you off being on all the time. The guages might work if you wire them the to proper sensors, just be prepared if it doesn't. Your Tach (if so equipped) will take a bit more work to make it work. I don't know how to start on that one, but there are some resources here that might be able to help you.
    FYI, in a 1985 4x4 Suburban with 31" tires, and 3.54 gears I was getting 24 mpg with a 6.2L, in my 91 with 31" tires and 3.73 gears, I got 22 mpg most of the time. If two 6K vehicles can get this type of mileage, your 3K truck should do quite a bit better. If you can get 3.27 or 3.07 gears you'll probably get over 30, but there are no guarantees.
    May 2005
    SE Wisconsin
    GM offered an S10 with an Isuzu, IIRC, 2.2l diesel. That might be an easy conversion. Isuzu also sold the clone vehicle. Unfortunately, those vehicles are not very common.
    1997 GMC Savana - 6.5 TD
    1967 Jeepster - Stock
    1986 Jeep CJ7 - Stock
    Jun 2008
    HH, you are talking about the Isuzu Hombre.
    I've never seen one with a diesel yet, just gas 2.2s.
    I called one of the yards here and they said they didn't know if they had any 6.2s...
    Might call some places in edmonton...
    It may be cheaper to buy an old truck with a 6.2 than to buy just the engine itself..
    Radiators and stuff, I'm sure with a bit of welding and cutting, I could a larger one mounted up.
    My truck has no A/C. No ABS, no air bags. Has power steering though.
    It has no tach either. I'd just make a custom cluster with AutoGauge gauges.. and I'd put a sticker in the glove box with the mileage of the truck when the engine was swapped.
    I'm planning on pretty much restoring the truck as much as I can, and if I had a diesel, I know the engine would last me a while and I could focus on the body or suspension..
    I'm going to see how hard it would be or how much it'd cost to get a larger rear end with a locker or posi and narrow it..
    EDIT: Called a place in edmonton, they said around $3000 for a used 6.2L, just the complete engine, no trans.
    Jun 2008
    I was looking at specs on the 6.2 + 6.5 Detroit Diesels on Wikipedia...
    "Common Problems Main bearing web cracks in both 6.2 and 6.5 engines. Reportedly fixed with a combination of improved higher nickel cast iron alloy and lower block re-design including but not limited to a main bearing girdle. These features are in the new for 2007 AM General GEP P400 6500 Optimizer 250-300hp enhanced 6.5 diesel presently being sold to Uncle Sam for the 6ton armored HMMWV.
    Crank failures. Related to age failures of the harmonic balancer, the vibration damped accessory drive pulley, or the dual mass flywheel.
    The PMD (Pump Mounted Driver) thermal failures. The PMD is screwed to the DS-4 injection pump on the 1994-2001 GM 6.5 diesel utilizing fuel flow to dissipate heat. The injection pump is mounted in the intake valley (a high heat area). The PMD contains 2 power transistors that should be cooled by proper contact with the injection pump body. If the pump is not precisely machined to make complete contact with the transistors via the silicone thermal gasket and paste, the PMD is improperly installed without the gasket or paste, the PMD is installed off center with the pump body, or corrosion develops on the mounting surface the PMD will overheat. Several companies manufacture an extension harness and heat-sink kits. These allow an owner or their mechanic to relocate the PMD away from the injection pump to a lower heat environment and/or a place that can get more air flow."
    Is there any way to fix these issues?
    Is there anybody selling new 6.2s? I seen some website that sells redesigned 6.5s, but no 6.2s.
    Dec 2006
    North Pole, Alaska
    Don't read too deep into those. Search this site. TONS OF INFO ON THOSE ISSUES!!! Leave Wikopedia alone, there's more and better info here.
    Cracked blocks, they happen, and normally don't affect the normal operation of the motor, and they can be repaired. I had a cracked block, I didn't reuse it, but the machine shop said they could repair it if I wanted to reuse it. Cranks, break normally because they don't like being ground (which many do when rebuilding). You also need to keep the harmonic balancer healthy which many don't verify often enough, and when it dies, so does the crank.
    The PMD issue with the 6.5 can be resolved by relocating the PMD to the nostril in the front bumper so it doesn't overheat.
    I agree with AKMark - there is a wealth of information on this board with broader, deeper, and more accurate information than you will find on Wikipedia.
    On your question about "new" 6.2 blocks - the last ones GM installed were in the '93 models, so it is getting pretty long in the tooth. Others would know much more than me, but there really wouldn't be much advantage to trying to build a "new" 6.2. You could do a NA 6.5 build if you don't want to mess with the turbo either due to added complexity or increased size. There are a couple NA blocks swapped into cars posted here on the conversion forum that you could take a look at.
    May 2005
    SE Wisconsin
    It would be the Isuzu Pup, same diesel engine as the S10. It would have been the previous generation to your truck. $3000 seems real high for a used 6.2, should be able to buy a whole used truck for that price.
