Transmission Trouble ??
I was pulling my travel trailer (10K loaded) up a moderate grade using tow haul a week ago when all of a sudden the transmission downshifted with a bang into 3rd gear and the check engine light came on. I continued up the grade in 3rd gear and pulled over at the top. Trans fluid was okay and was only 170 degrees when the downshift occurred. Finding nothing wrong I cycled the key a few times and pulled back out onto the highway. (With 1000 miles to go) The worry some part is the transmission had not downshifted back to low gear when I stopped and it started out from a dead stop in 3rd gear. Easing it along I drove a few miles (still locked in 3rd gear) keeping rpm around 2200 and transmission temperature under 200 degrees. After driving about 30 miles in this condition I found a large parking lot and pulled into it. Again fluid level was a little higher but not over the full mark. I again cycled the key about 5-6 times, but let the truck sit for about 20 minutes. This time when I pulled back out on the highway the transmission shifted normally and started out in 1st gear, but the check engine light was still on. After an overnight stop, the next day the check engine light was OFF and the transmission shifted normally for the rest of the trip home.......Trans sump fluid and filter were changed 5k before this occurred. 152K on transmission.......Any idea what happened. Shift solenoid ??
2005 Chevy 2500HD, CC, SB, 4X4, Duramax, ARE Topper, 60 gallon RDS toolbox/tank combo, Kennedy Headlight Booster, Isspro pyrometer and boost gauges, EGR Blocker, PCV Kit, Bilsteins, 265 Michelin MS-2, TTS Exhaust, pulling 35' Jayco travel trailer.
