Results 1 to 2 of 2
Thread: Will it bolt up
    Mar 2018
    Minnesota
    Default Will it bolt up
    I have a 93 regular cab 3500 6.5, pretty rotted out bed and cab. Found a 93 1500 regular cab with good body really cheap. Will the half ton body bolt up to my one ton frame? The body looks identicle but of course there’s always something. Thanks
    Hi
    The body should bolt up fine.Maybe some minor differences.
    You may have to change the wiring harness,depending on the power train in the 1/2 ton.Still not a real big job compared to welding and body work to fix a rotted out cab.
