Go Back   TheDieselPage.com Forums > Other Diesel & Truck Related Forums > Diesel Conversions
Diesel Conversions Convert gas to diesel, or convert to a 6.2/6.5/Duramax/Cummins/Navistar/Isuzu/Perkins/Detroit/or ... diesel engine. Go here to see completed projects, works in progress, share your conversion or ask the experts.
Old 06-13-2007, 04:32 PM
gophergunner gophergunner is offline
i'm special
Default Detroit Diesel
ok, so i think i'm a little obsessed with the old Detroits, but i just love the sound they make. Now i've been thinking for a while that i would like to have an old 2-stroke in a pickup truck but i'm not really sure which to use and even if i decide i will need some help on picking a transmission and transfer case combo.
so the contenders as of now are a 3-53, 4-53, 6v-53, or a 4-71
3-53 seems a little underpowered for my likings, but very economical and still has the great sound.
4-53 seems little better but i just have to watch the weight of the whole thing. these aren't exactly meant for pickup trucks.
6v-53 is supposed to have a fair amount of power and a bit higher reving
4-71.......well i was told the 71 series was the best engines detroit ever made
right now i'm leaning towards the 4-71 because i have found an aluminum bare block (no crank or head or any other parts) which works quite well since i would have rebuilt the whole thing anyways. The aluminum block will save me lots of weight, as its apparently only about 175 lbs according to the seller.
now i'm just wondering if anyone else has any input here, or if i should ditch the aluminum block for some cast iron, or else a different series engine altogether. don't even mention cummins because they could never make me as happy as an old detroit could.
if your curious about what i'm putting it in, i'm thinking about a 1969-1972 body style, 3/4 ton 4x4 gmc. of course i would start with this engine and build the truck from the groung up i think. if i'm going to do it i might as well do it right.
2011 VW Jetta TDI, pretty well loaded without leather.
2006 GMC Sierra D-max, 4x4, 4 door, bumper, winch, Espar heater, and the HID lights are a nice touch too.....
1986 GMC 3500, 454 on propane, 4 speed, 4x4, crew cab dually......the welding truck
1984 Toyota 4x4 pickup, 4.3 V6, 700R4, Toyota t-case.......transforming into 4x4 cage buggy
Old 06-13-2007, 05:32 PM
Craig M Craig M is offline
Quite a few have done the 453/453T in 3/4 and 1 ton trucks. Most have been very happy. The 6V53/6V53T will give you the maxim power, but like you said, a bit heavy. Have not seen a 471/471T in a pickup. Others have stated the additional height will make the install a bit tougher than the 453T. An aluminum 471T should give you good power and a reasonable weight engine. Tie rod, oil pan, steering, transmission hump, engine mounts are all issue that may have to be dealt with during the install. Saw a 671 in a 3/4 ton Ford, so if that can be done all else is gravy.
Old 06-13-2007, 08:53 PM
i'm special
from the info i found online the 471 is only a few inches difference in height compared to the 453.
i just have a good lead on that aluminum block and i hate to pass it up if its a good and very possible conversion, but i also hate to waste my time if there is a better detroit option for a pickup.............but if a 671 can fit in a 3/4 ton i shouldn't have any trouble.
Old 06-14-2007, 08:47 AM
The 671 fit, but not without problems. No engine fan, used electric pusher fan on the bumper side of the radiator. Firewall was "extended" into the cab area to get the long 6 cylinder in. The guy got the 671 cheap, so did not mind the extra work to install it. A 471 should not have the fan/firewall issues. 2 inches is not much, but the clearance from steering/suspension to the hood are tight. A louvered hood could solve the issue.
  #5
Old 06-14-2007, 10:15 AM
i'm special
well i'm going to try to get this 471 and rebuild it.....might take some time tracking down parts and that because its just a bare block. but i think a body lift might help solve any height clearance issues.
another problematic area will be clutch, transmission, and transfer case......don't even know where to start that would fit any of these detroit engines and would also work well for a pickup application
  #6
Old 06-14-2007, 02:52 PM
Transmission should not be a problem. Allisons auto's (old style AT545 or similar) or various manuals will bolt right up. Lots of old manual transmissions at local wrecking yards. I saw that aluminum block on ebay also. You might want to buy a "parts" 471 to get all the components you will need at a reasonable cost. Rebuild kits will have liners, pistons and that, but lots of small parts will be required, and buying them from a parts store could get expensive.
  #7
Old 06-15-2007, 01:12 PM
6.5NOVA 6.5NOVA is offline
Smile My detroit powered pick-up
Take a look...........
http://videos.streetfire.net/video/6...3d011bba43.htm
twin turbo 6V-92 with 157 mm injectors...
chevy Nova sedan 1977 <br />6.5 HD diesel/ 4L80e<br />Gear drive timing set<br />Ram air, E.P.S. steenlessteel exhaust<br />2.73 axle ratio/ 205-65-R15 tires<br />new projeckt: dodge W200 with detroit 6V-92
  #8
Old 06-16-2007, 12:42 PM
arveetek's Avatar
arveetek arveetek is offline
Moderator-Towing Forum
Quote:
I, too, once saw a 6-71 in a 3/4 ton Ford once. Seems like it was an early 70's or late 60's model Ford. I saw it at a truck and tractor show in Republic, Missouri.
I've seen a couple of other pickup trucks with 6-71's shoe-horned into them, but it is a tight fit and a lot of fabrication is necessary.
My dad has a 6-71 mounted in a custom truck he's building, but he now wants to find a 8.3L Cummins to replace it. He's decided the Detroit would be a bit loud for highway use.
1995 K1500 Tahoe 2 door, 6.5LTD, NP241, 4L80E, 3.42's, 285/75R16 BFG K02's, Kennedy OPS harness, gauges, and TD-Max chip, Dtech FSD on FSD Cooler, vacuum pump deleted, Turbo Master, 3.5" Kennedy exhaust, F code intake, '97 air box, dual t/stats, Racor fuel filter, 320K miles and running strong!
  #9
Old 06-20-2007, 10:15 PM
i'm special
i called up a local fellow who deals with old detroits and rebuilding and what not. i tell him what i want to do and the first thing he says is cummins 5.9 litre.........he's not discouraging me yet but the aluminum block on ebay is about to end, sorry if anyone else is planning on bidding on it, but i think i might as well take a chance on it because the aluminum ones don't come up too often.
just hoping for that last little bit of input someone might have about a 4-71 being a bad choice.........anything at all??
  #10
Old 06-21-2007, 08:48 AM
The Cummins is a good engine, but does not have the sound of a Detroit 2 stroke. An aluminum 471T will be a relatively light good torque diesel engine. If shipping was not $203 I might consider that aluminum 471 block.
