TheDieselPage.com Forums
2017 - TDP's 21st Anniversary
Go Back   TheDieselPage.com Forums > Chevrolet & GMC 2500HD/3500 Light Trucks > 2500HD/3500 HD Trucks & Drivetrain
Reply
Thread Tools Display Modes
  #1
Old 02-12-2017, 11:11 PM
gary_lucas's Avatar
gary_lucas gary_lucas is offline
Enthusiast
Default Got a huge estimate from a mechanic.
I brought the truck in for an oil change and diagnose a coolant loss + overheat.
Original thread here: http://www.thedieselpageforums.com/t...ad.php?t=45049
Among the many things they found on top of the 'head gasket failure' (for which they quoted $8k:
  1. Inner / Outer tie rods w CA$1,050.00
  2. Upper / Lower Ball joints CA$1,480.00
  3. Front Brake Pads / Calipers / Rotors CA$1,150.00
  4. Stearing Gearbox leaking + has play CA$795.00
  5. Pitman arm worn CA$458.00
And a few other things ...
I just did the calipers / brake pads / rotors. I knew going in that those were almost done (and they were... I was about to hit the anti wear tabs any minute). But I was quite surprised to find no play in the steering / suspension that I could tell... Like at all. The tie rods seemed fine, No play that I could sense. if I wiggled one wheel even barely moving it the other wheel seemed to move with it... Did that on both sides, I couldn't detect any play whatsoever, side to side or up and down...
I'm also not an expert either though. Anything I could be missing? My understanding is that these parts need replacing when they show signs of wear. IE when there's play in the system or if their damaged.
Also, if the shop was really trying to make allot of money off of me... What's the chances the head gaskets are ok too? Seems unlikely to me. I've pressure tested before and aren't losing fluid except under load it seems... How do I confirm?
__________________
GMC Sierra 2500hd 2004.5
  #2
Old 02-15-2017, 11:23 AM
Kennedy Kennedy is offline
I can about guarantee the pitman and idler arms are shot. Jack the truck so that the RF wheel is off the ground but not the left. Try to steer the RF tire by grabbing at 3 and 9 oclock. Watch as the drag link rises and falls and the RF tire moves without moving the LF. You can also put a big pipe wrench on the drag link and rotate it.
We do pitman/idler supports on new OE arms typically.
__________________
  #3
Old 02-15-2017, 10:13 PM
gary_lucas's Avatar
Enthusiast
Thanks!, I'll check that out out in the next little while. I hadn't heard of pitman / ldler supports before. I'll check that out too.
I'm starting to seriously consider installing a lift in my garage... I think it would pay for itself this year...
__________________
Reply
Thread Tools
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
