Thread: Compressor Upgrade
    Jul 2013
    CENTRAL MISSISSIPPI
    Default Compressor Upgrade
    Greetings from Mississippi. I have a question I was not able to find an answer to in the search files. What are our options as far as a/c compressors? I change the R4s to Sandens on gas engines, but on my '94 6.5 there is not enough room to retrofit a Sanden in the stock R4 location. Is there a better R4 style compressor available or should I just buy the best quality R4 I can find? Thanks
    Andy
    The R4 is not a bad compressor.
    The issue is that after a compressor failure the system is full of crap from the train wreck that occurs when these pumps fail.
    A good flushing of the entire system, replace the accumulator and then recharge with the prescribed oil and refrigerant.
    The R4 pumps just will not tolerate crap running through them.
    I have seen R4's replaced due to failure that only lasted a month.
    Getting the system clean is the key.
    You may consider adding a filter on the return line.
    Good luck.
    Jul 2013
    CENTRAL MISSISSIPPI
    thanks. I am gonna upgrade the condenser at the same time. filter is a good idea!
