Results 1 to 2 of 2
Thread: mitsubishi swap
    Feb 2013
    alabama
    Default mitsubishi swap
    We are swapping an 88 mitsubishi montero gas to a diesel. It is a mitsubishi and came from a montero but we don't know the year. It is an injector pump though. What we need to know is Does it need a lift pump and how do we prime it?
    Hi
    I would get an electric one and use it,can't hurt.Sounds like even the Duramax can benifit from one.With a manual switch it makes priming the filters easy.
    Thomas
