Results 1 to 9 of 9
Thread: Oil cooler lines
    Mar 2010
    Default Oil cooler lines
    Well I hoped it would never happen since my motor change about a year ago I put in brand new oil cooler lines. I just had one blow out in the rubber hose yesterday driving down the road . I got it shut down before any harm was done (I hope) I seen my gauge fall and shut it down . SOOO im take them back to the parts store and get my money back since there lifetime lines.
    Now where can i get braided steel lines to replace the factory ones ?
    Brian
    1994 GMC 2500 6.5LTD 4wd
    Marine injectors and built 4911 pump to run veggie oil
    1981 Toyota 22L Diesel Pickup
    Mar 2010
    Default plug the holes
    Well when i can afford it im going to get a set of lines from one of our advertisers but until then . Would it hurt to plug the lines and run it without the cooler ? I would like to drive it since its costing me money to drive anything else , Since the burb runs on veggie oil
    If you run it without a cooler, you won't need a cooler. For that engine, anyway.
    Mar 2010
    Ok well than i might just plug the holes in the block and run it that way till i can afford or feel like replacing them . Thanks
    Feb 2003
    Grand Rapids MN 55744
    Running it without the cooler will toast your engine.
    If nothing else get the "lifetime" cooler lines that you had replaced with warranty....maybe this time you will get good ones...
    2001 Chinook RV, V10 gas
    1967 GTO, 1989 Honda Transalp
    3 kids, 1 wife, 1 dog
    Yeah, you missed the gist of DMax’s statement - that you won’t have to worry about a cooler for THAT engine as you’ll be looking for a NEW engine in short order…
    Looking at it that way, $150 is pretty cheap: http://www.lubricationspecialist.com...-cooler-lines/
    Quote Originally Posted by Hooptybass View Post
    I suppose I should have been less vague. Running w/o an oil cooler will not end well, for THAT engine. It will end, and right soon. I do NOT recommend it.
    Mar 2010
    Ok thanks . I will call and talk with them at Lubrication specialists. Since my motor came out of a box truck . Its not the same port sizes on my motor than the stock ones .. Thanks guys
