Thread: Front wheel speed sensors,,,
    Feb 2010
    Question Front wheel speed sensors,,,
    On a 95 K3500 dually 4WD do I have to remove the front wheel bearing and then drive out the wheel studs and remove brake disk to replace the wheel speed sensors?
    To replace the wheel speed sensor, you'll need to replace the hub/bearing assembly (which may have the studs already installed). Double check, but I think they were R/L specific.
    Feb 2010
    Pretty sure brake disk on a 95 goes on the back side of the wheel flange, not between the wheel and the hub like the newer stuff.
    OK. Then you'll have to drive studs.
