Thread: 95 k2500 a/c blend doors
    Festus, MO.
    Default 95 k2500 a/c blend doors
    My 95 K2500's air conditioner seems to have a mind of it's own. I can put it on max a/c and hit the recirculation button and it will kick up and run like I think it should. Or at least it sounds like it.
    However I have air coming out of everywhere, defrost vents, floor, etc. If I select floor all the air comes out there, If I select defrost all the air comes out there.
    So I don't know if I have a blend door or max a/c issue... or both.
    HELP
    Big Green
    Jan 2005
    Denville,New Jersey
    That sounds like it's running normal. Can the a/c cool the cab ,when you get on your way, or does it take a long time?
    Festus, MO.
    It cools the cab but with the max a/c having a mind of it's own it takes longer than I think it should.
    the air coming out is nice and cold.
    It's just when I put it on max I expect it to stay on max until I turn it down or off.
    Big Green
    Jan 2005
    Denville,New Jersey
    Have you checked to see if it will take some more R134 freon? , maybe it just needs topping off.
