Results 1 to 2 of 2
Thread: Need to Realign Rear Axle on Topkick C7500
    Nov 2012
    Newfield, NJ, USA
    Exclamation Need to Realign Rear Axle on Topkick C7500
    I need to realign the rear axle on my 2005 GMC Topkick C7500. I can not find the procedure in any of my manuals or on Mitchell to do so. My rear alignment is 3/8" out. Does anyone have experience doing it? If I cut my U bolts loose and replace them can I adjust it and compensate for the 3/8" difference?
    St. George, Utah.
    Question
    Just a thought, is it possible that the lagging side has a partially sheared alignment pin? That is the pin that is on the center of the top leaf that the third member is set over and the secured with the U bolts. The pin actually goes through the complete spring stack. The only other possibilities would be a badly worn front spring curl bushing or worse case a bent frame. Just thoughts.
    Denny
    2018 GMC Denali HD 2500 L5P.
