Thread: 1992 6.2 cranks but wont start
    Jul 2014
    Ohio
    Default 1992 6.2 cranks but wont start
    My teenage son has a 1992 Chevy K2500 6.2 diesel truck. We were hauling water and it surged a little then died. We haven't been able to get it to start since. It will turn over, but won't start. We have replaced the IP with a brand new one & lift pump. We were wondering if it was getting fuel, so we put a clear filter in the fuel line so we could see what it was doing. We have also bypassed the tank & line, putting a line straight from a can of diesel fuel to the IP and took the glow plugs out. We are getting a spray of fuel out of each glow plug hole. We put the glow plugs back in and it still won't fire. We also tried spraying a mist of high powered starting fluid above the intake holes and it still won't start. Any suggestions on what to try next?
    Feb 2003
    Grand Rapids MN 55744
    Howdy
    Fuel + Air + Compression = FIRE.....seems like the only thing you haven't checked is Compression...
    Also is the timing set right...so that the fuel is entering the cylinder at the right time.
    2001 Chinook RV, V10 gas
    1967 GTO, 1989 Honda Transalp
    3 kids, 1 wife, 1 dog
    Sep 2001
    Concord, NC, USA
    Checked glow plugs??? Unless the engine is hot or in really good shape, the engine won't start without some glow.
    Mark Chapman DP member #653;
    1983 K2500 6.2 Suburban, 4" lift, 35" tires, ATS turbo, Banks exhaust/intake, pyrometer, tachometer;
    1986 K5 6.2 Blazer, 2" lift, 33" tires, Banks intake, pyrometer, tachometer
    1963 wife, one owner, average mileage for the age but in excellent shape, a keeper
    1992 daughter, low mileage, pretty, limited edition, but requires some money to maintain
    1995 son, sports model, very fast & peppy, time will tell on durability and maintenance costs
    "Grease is good"
    Dec 2003
    Yukon Canada
    If you have a block heater,plug it in and it may help in getting it warm enough to start.
    Thomas
