Results 1 to 11 of 11
Thread: Optimizer 6.5 T/D Oil Filter Adapter
    May 2014
    us, ga
    Smile Optimizer 6.5 T/D Oil Filter Adapter
    So I have a new engine going in a 95 2wd dually. The old blown engine that I took out had an oil filter adapter. I'm assuming it's for clearances in certain applications. I installed that engine probably 15 years ago, and think we took it out of a suburban. Anyone have any additional information regarding this adapter?
    The adapter is for 4x4 applications. Nothing special or more than that.
    May 2014
    us, ga
    I figured as much. So my oil cooler lines (aluminum I think) that bolt to the block are bent and restrictive. I'm thinking about just using fittings to braided high pressure line, cut to fit. Any thoughts? Thanks
    The oil cooler lines you describe are similar to what TDP vendors sell. If you have the means to build your own, by all means, do so. Otherwise, you can buy a kit. The OEM lines have never been reliable. The same applies to PS lines, although less catastrophic when they fail, and they aren't out of sight.
    May 2014
    us, ga
    I can make my own, or have them made to length but want to look at TDP? Do you have a website address or link etc? I can't find it. Thanks
    The TDP (The Diesel Page) vendors support this forum, and ensure we can continue. Please visit This Page. Lubrication Specialist (member Greg Landuyt) stocks and sells the kit I referred, although there may be others I don't know of.
    Ft. Wayne, In.
    I've purchased Greg's (Lubrication Specialist) Oil cooler lines for my Tahoe. Work great and quite affordable. I doubt I could have had our local hose shop build them as affordably. Perfect fit first time, no hassle.
    Give Greg a call and talk to him.
    Dave
    Dave, N9LOV
    Member #242
    Dave's Diesels:
    '97 2 Dr Tahoe, Intercooled,
    Kennedy ECM, 4" Exhaust
    '02 GMC
    Another vote(s) for Greg’s lines. I have them on my K2500 and Yukon.
    To expand on the adapter, for 2WD the oil filter just comes straight down while the adapter points it forward so that it misses the 4WD driveshaft.
    Ditto - on the oil cooler lines and the adapter. I have Lubrication Specialists' oil cooler lines on my Tahoe. Good product.
    The 90 degree adapter points the oil filter horizontally instead of vertically to make room for the front driveshaft. Makes oil changes a real pain. I keep talking of doing a filter relocation kit, but after 12 years and who knows how many thousands of miles, I still haven't done it!
    May 2014
    us, ga
    Does Greg make the power steering hoses as well? I did have an oil cooler hose blow in the street in front of my house, took about 6 hours with a pressure washer and degreaser and 2 years to fade the stain away. Nasty blowout. I've been building this truck for 2 years now, just want to get it right. Thanks yall.
    Ft. Wayne, In.
    I suggest calling Greg to find out. His website is pretty good though as I recall.
    Dave, N9LOV
    Member #242
    Dave's Diesels:
    '02 GMC
