Shaved block?
So, yesterday I started cleaning the block to put on my new heads and found these numbers on the top of the block rail 05yfz020.
I am guessing this block has been decked by .020 of an inch on that side in 2005?
I plan on measuring the difference in the gasket thickness between that and the other side today when I get home from work.
Input welcome!
Also what is the gasket number I need to order for the thicker gasket?
Thanks again
1995 Chevy 2500, 6.5L Diesel mostly stock 234,000 miles. Changed the water pump to HO WP, deleted the vacuum pump and added a mechanical wastegate controller made by me with info from others on the forum.
