TheDieselPage.com Forums
2018 - TDP's 22nd Anniversary
Go Back   TheDieselPage.com Forums > Chevrolet & GMC 2500HD/3500 Light Trucks > Duramax 6600
Duramax 6600 Discussion Forum for the Duramax 6600 Diesel Engine, including the LB7, LLY, LBZ & LMM engine specific topics.
Reply
Thread Tools Display Modes
  #1
Old 08-09-2017, 09:18 AM
HueyC2 HueyC2 is offline
Newbie
Default Need a good Duramax Shop In LA area
I'm looking for an excellent Duramax repair shop in the greater LA area.
My '06 LBZ is overheating when I pull my 5th wheel trailer up a steep grade. At all other times every thing is fine. I have replaced the (2) thermostats, the coolant tank cap
and have bled the system. It's looking like head gasket time!
If Kennedy Diesel was closer, I would be there in a heartbeat.
  #2
Old 08-10-2017, 06:38 AM
Kennedy Kennedy is offline
Please define "overheating"
If you have any sort of miles I would pull the radiator and wash the air side out as well as the rest of the cooling stack for starters. Then try fan clutch, belt, pulleys etc.
__________________
  #3
Old 08-10-2017, 09:37 PM
gary_lucas's Avatar
gary_lucas gary_lucas is offline
Enthusiast
I had a similar problem. It eventually turned into a head gaskets issue.
The original overheat was definitely crud in the air side of the radiator.
As kennedy suggested... Take the shroud off the cooling stack... Pull the stack if you're not sure.
Don't mess with it, take the hit and pull the radiator... Powerwash the air side.
I tried delaying it and I think that contributed to a very, very large repair bill.
__________________
  #4
Old 08-11-2017, 08:12 PM
Newbie
Default Overheating
Hi Kennedy
When I pull my 5th Wheel, GVWR 14K, everything is fine until I come to a steep hill. I will shift down and run at 2500 to 3500 RPM. The temp gauge will go up to a little past 210 deg. and the fan will come on. The temp will drop to normal, but my right side mirror will be wet from the coolant that has been forced out of the plastic tank. Even after sitting overnight, when you remove the cap from the coolant tank, there will be pressure that will cause the coolant to come out under the cap. If you maintain hand pressure you can reduce the pressure slowly, thus no coolant expelled.
Thanks for you reply.
Reply
Thread Tools
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
