TheDieselPage.com Forums
2018 - TDP's 22nd Anniversary
Go Back   TheDieselPage.com Forums > Chevrolet & GMC 2500HD/3500 Light Trucks > Duramax 6600
Duramax 6600 Discussion Forum for the Duramax 6600 Diesel Engine, including the LB7, LLY, LBZ & LMM engine specific topics.
Reply
Thread Tools Display Modes
  #1
Old 08-18-2017, 06:58 AM
rickstrk's Avatar
rickstrk rickstrk is offline
bumper
Question 03 idle smoke
Started about year & 1/2 ago at 175 k.
I put in Standyne injector cleaner in tank and smoke went away for 5k. After a few K more smoke I tried Standyne again. No help.
Filled new fuel filter with Seafoam injector cleaner, let idle 3 mintues, shout down for 15, then drove like I stoled it for 30 miles. Per Seafoam instruction. No help.
Added 8 onces of Standyne to tank of 5 gal. Then 8 onces to last 2 gal. Ran till had .45 gals left. NO HELP.
Smoke did not look never blue in beginning but now does look blueish. After idling at light for 30 seconds it smokes bad at first leaving light.
Injector or is there other things?
PS truck bone stock, never uses oil. Runs fine.
__________________
________________
03 GMC Xcab 4x4 lng box 2500HD D/A stock+bumper
  #2
Old 08-18-2017, 08:00 AM
Kennedy Kennedy is offline
Definitely injectors. Std VCO injectors are a crap shoot in my opinion. We've been using the SAC type nozzles with complete success as they never do this blue/white smoke deal.
__________________
  #3
Old 08-19-2017, 07:52 AM
More Power's Avatar
Administrator
If you have a reader, it would be interesting to look at the fuel-rate balance for the 8 injectors. Smoke is due to leakage... A bad leak can damage pistons. I'd not wait too long to get a fresh set of injectors.
If you're not equipped to do this yourself, investigate the mechanics in your area -looking for someone with considerable experience/success with the LB7.
If money was not a problem, refreshing the head gaskets and water pump at the same time as the injectors would/could be a good move if the work came with a 12 month unlimited mileage warranty.
A lotta 'ifs".
I'd listen to John about the injector type - to use during a replacement.
  #4
Old 08-20-2017, 11:32 AM
rickstrk's Avatar
bumper
Thanks for info. Will have injectors done soon(3k OR hunting trip.). Will get balance rate before inj.
Did a little checking and couldn't find SAC injectors for stock they seem to be 45% min. Like to be stock if I can. I would only do chip for economy.
Head gasket? I'll have compression check for piston info. Replace water pump myself 30K ago. I could do all the work but at 69 I'm not interested in standing on my head that long. Lol.
Truck is worth 15K max so 5K of work is about it. Not sure I want a newer truck because I got all the dings in this one.
Oife is good.
__________________
________________
  #5
Old 08-21-2017, 08:49 AM
In my experience when these injectors they will run fine, idle smooth, no evidence of any issues other than this nozzle weep when warm.
As for cost justification I think the value of the truck may be low, but lower in it's present state and fixed right it should last a long, long time.
__________________
  #6
Old 08-21-2017, 04:10 PM
rickstrk's Avatar
bumper
No stock SAC style ? Will your 45% run great stock (no chip)?
__________________
________________
  #7
Old 08-22-2017, 06:21 AM
Quote:
Stock or near stock SAC would be my first choice were they available. I have quite a few guys running the SAC 45's with stock tuning. Many opt for a custom tune though as a little sprucing up of the timing goes a long way on any LB7 or any Dmax for that matter.
__________________
  #8
Old 09-21-2017, 08:25 AM
rickstrk's Avatar
bumper
just a little update. Injector cleaner don't quickly clean injectors. After a Seafoam full filter then very heavy load of Standyne cleaner in 1/4 tank. Had to run more than a tank before it cleaded up.
May still need injectors in future but don't need to get in big hurry.
Will run injector cleaner every 3 or 4 tanks and save 5 grand for later date.
2 years a go it cost me $350+shipping restocking because had to return injectors. Thought it was making oil.
Injector cleaner ismy friend.
Thanks for advice.
Life is good.
__________________
________________
  #9
Old 12-27-2017, 04:15 PM
rickstrk's Avatar
bumper
Default Making oil. Not!
When checking oil you MUST pull dip stick wipe clean then reinsert & check. Because it a sealed system (vacumn ) and will read over full.
PS got 5000 miles after running lots of injector cleaner. Don't get in hurry to put in new injectors.
__________________
________________
  #10
Old 12-27-2017, 04:46 PM
rickstrk's Avatar
bumper
Finely cleared up . Have 190k+ on truck now. Will try same next time it starts smoking.
__________________
________________
Reply
Thread Tools
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
