Go Back Forums > The Diesel Page Member Forums > 6.5L Turbo Diesel
Old 12-01-2017, 12:33 AM
Tim. Tim. is offline
Default Chevy 2500 6.5
Hello sorry probably you guys answered this probable cause but i just recently bought a chevy 2500 96, and i have this wierd problem with and misfire sound like its only in one cylinder driver side but it doesnt misfire all the times it will sometime do it when it idle and the constantly misfire constantly when i reach last gear 2000 rpm but when i pass 2000/2150 rpm itll be all good, any suggestions
Thanks... Tim
Plus at this moment my wastegate isnt functioning cause of the vaccum pump could that cause the problem or not ?
Old 12-01-2017, 07:05 AM
Robyn's Avatar
Robyn Robyn is online now
Missy Good Wench ( Moderator)
Welcome to TDP
The misfire is likely a failed injector.
Any SES LAMP Showing ???
If so get the codes
With the engine running (And missing) crack open each injector line (one at a time) and see which one does not cause a change... Sort of like pulling a spark plug wire on a gas engine to isolate a misfire...
Once you locate the cylinder not fireing... Remove the injector and switch it to the cylinder next to it (just swap the two) Restart the engine and see if the issue follows the injector.
If the issue follows the injector then the one injector is bad for sure.
If the issue does not follow the injector then there are other issues such as the injector pump ??????
The vacuum pump will not cause the issue, but you need to get it fixed to have the engine operate properly (Turbo boost and power)
Good luck...Keep us in the loop
(1) 95 Suburban 2500 4x4
(1) 2017 Mercedes C class
(1) 1997 Astro "CATVAN II"
Old 12-01-2017, 05:09 PM
JohnC's Avatar
JohnC JohnC is offline
Enemy of the State
Default Zombie apocalypse
Wow! This thread is more than 11 years old...
-Joseph Sobran
Gone but not forgotten: '87 F350 7.3, '91 C2500 6.5, '95 K2500 6.5, '06 K2500HD 6.6
Copyright 1996-2018 by - All Rights Reserved
